Product Options with Ecart help
Thread begun 10/25/2011 7:29 pm by johna1964 | Last modified 11/02/2011 9:48 am by johna1964 | 5240 views | 9 replies |
johna1964
Hi!
I have already added the necessary column to the ecart object, updated the cart page, and added the product options to the database. I decided to place the add to cart button on the results page and use the long description there. I just need to make sure I can follow the instruction the same as the detail page in the Product Options with eCart tutorial, but on the results page, without any problems.
Thank you!
johna1964
using product options on the results page will take a good deal of familiarity with PHP Code, Recordsets and SQL.
the problem is that the Recordset to look up the option for the product will need to go Inside the product repeat region, it will also need to use the product ID from the product recordset to filter.
It _can_ be done if you have a good deal of php coding experience.
johna1964
Hi Jason,
Thank you... I am flying by the seat of my pants as it is ... :)
Would you be willing to assist me this?
johna
It's not really something I can offer support for through this forum, If you need assistance with this, I would suggest signing up for a premier ticket where we could work with you in a one on one session.
johna1964
Thank you
Jason,
Thank you...:)
johna
johna1964
Little Problem
Since I had already edited the ecart as explained in the Product Options with eCart instruction, I just now noticed the server behaviors panel in the cart.php has duplicated the buttons? You can also see the exclamation points...
What do I need to do about this and does effect the functionality of the cart?
Thank you! :)
johna1964
you can select each of the duplicate buttons and click the minus button to remove them.
A red exclamation mark only means that there is code on the page dreamweaver is having trouble inspection. It means there may be a problem on the page and there may not be.
Test the page in the browser, if it is functioning correctly, ignore the exclamation marks, if not, then the exclamation mark is a good place to start investigating.
johna1964
checkout is not working
Jason,
Hi again... the checkout button is not working. I have uploaded the cart.php page. I'm sorry, I don't know what I'm looking for. :(
Thank you!
johna1964
the code is looking for a button named "eCart1_Checkout", but your checkout button is named "eCart_Checkout"
change:
<input type="submit" name="eCart_Checkout" id="eCart_Checkout" value="Checkout" class="ImpressionsInspiration22" />
<input type="submit" name="eCart1_Checkout" id="eCart1_Checkout" value="Checkout" class="ImpressionsInspiration22" />
johna1964
cart page is working now
Jason,
Thank you! :)
johna1964
