Spellchecker
Thread begun 10/21/2011 5:52 am by Rune Brynestad | Last modified 10/25/2011 12:20 am by Rune Brynestad | 1457 views | 2 replies |
Rune Brynestad
Spellchecker
Is it possible to turn off the built in spellchecker? It's only trouble with it. Here is an example.
I'm writing some content in the edtor. It looks ok, so I click Update. (Image 1)
I open the content later to edit it (Image 2). As you can see the spell checker runs automatically and marks the words that are unknown. The most annoying is that the spellchecker also add &nbsp; after the <br /> tags for the words marked as unknown. This is making trouble when I'm going to update the content again, and I have to remove the &nbsp; manually.
Regards
Rune
in the admin/contents_insert.php and contents_update.php, look for the following line:
$CKEditor_config["scayt_autoStartup"] = true;
and change it top false:
$CKEditor_config["scayt_autoStartup"] = false;
Rune Brynestad
Perfect!!
Thanks.
Regards
Rune
