Ue401
Thread begun 10/18/2011 11:25 pm by michaelf0199272 | Last modified 1/11/2012 8:41 am by Jason Byrnes | 5765 views | 13 replies |
michaelf0199272
Ue401
Messages in the sent UE emails are stll transparent despite that I put the HelperPHP in
C:\Users\Michael\AppData\Roaming\Adobe\Dreamweaver\CS4\en_US\Configuration\Shared\WebAssist\DigitalFilePro\HelperPHP
It did not seem that the fix worked.
in the universal Email server behavior, did you check the option to Create a File for the email, then select to use one of the email templates?
if you did not check that option, did you click the DW Edit icon to design the body of the email?
you need to use one of these 2 paths to create the email message that will be sent.
michaelf0199272
I checked the box and selected the box format.
please send a copy of your page and the webasisist/email folder
michaelf0199272
Please find two zipped webassist files (Webassist fold and the index.php) also find the website link.
www.toptobottomhomerepairs.com/
Thanks,
you have the forms action set to post to another page:
<form action="#/modules/ajax.php?processContactForm" name="contact_form" id="contact-form" method="post">
change that so it posts to itself:
<form action="" name="contact_form" id="contact-form" method="post">
michaelf0199272
I am still getting the same result after the changes that you suggested.
peacehawk
Installed UEmail and boy oh boy
Using dreamweaver cs5.5, Mac OS 10.7.2, I installed UE and was prompted to uninstall CSS FormBuilder and ImageResizer or problems will occur when opening dreamweaver.
We'll, I did just that and when I went to the Video you provide on using UE 4.01 it starts out by saying it designed the form in CSS FormBuilder 2.0.0. So, I reinstalled the CSS FormBuilder and WHAM-O, I get the error message again. What gives? Here I upgraded and once again I can't utilize the software because of issues I can't seem to control. HELP!!!!!!
Jim Graniela
Universal Email 4.0.1 is a part of CSS Form Builder 2.
If you have CSS Form Builder 2 installed, you do not need to install Universal Email 4 because all of the functionality is already included.
you should not install both extensions together.
