Another way to install extensions?
Thread begun 9/23/2011 4:34 pm by a2d | Last modified 10/03/2011 9:29 am by a2d | 8898 views | 6 replies |
a2d
I wasn't sure where to post this but hope someone can answer this question for me. It seems there is some issue with a lot of people and installing extensions using the Adobe Extension Manager on Win 7 64 bit. I have researched and cannot find an answer why my extension manager isn't loading. It shows in my processes but does not work. If I click on the extension it doesn't install neither.
Is there another way I can install these extensions. Just purchased the social media tool and cannot use it. Any help would be greatly appreciated as Adobe is no help. You would think since I paid a few thousand dollars for their software they would help but they don;t have an answer and there are many with the same issue.
extensionmanager?view=discussions&start=0
Thank you,
Ernie
No, there is not another way to instal the extensions other than through the adobe extension manager.
One thing i would try is to rename both the DW and extension manager configuration folder.
see the Common installation issues PDF for details on locating the Dreamweaver Users configuration folder:
instead of deleting the cache file inside the configuration folder, rename the configuration folder.
In the Adobe folder, there is also a folder for the extension manager, this will lead to the extension managers configuration folder, rename that folder as well, then try loading the extension manager again.
a2d
jason, thank you but no cigar...
Jason,
Thank you for your input, but unfortunately that does not work. I did however figure out where the issue is coming from. I did everything other than do an uninstall then a clean install of my creative suite (which I do not want to do b/c I have so many settings saved in all my programs).
I tried what you suggested and no cigar.
What I tried is creating a new test user account in Windows. I set that test account to have admin rights. I logged in then clicked on adobe extension manager and BAM! it opened and worked. Unfortunately, the extensions from one user cannot be user and do not carry over to the other users.
What I am wondering is is there anyway to have these extensions carry over to the new test account , i.e. install a new one and be able to use it in my original user account.
Any other input is very much appreciated.
Thanks,
Ernie
p.s. Windows 7 Home Premium, i7-2820QM CPU@2.30 Hz, 8 GB RAM, 64 Bit.
No, there is not a way that I am aware of to have the extensions for one user account carry over to another user account.
a2d
Fixed my issue with a complete restore
Fixed my issue with a complete restore from a backup I had from a month ago.
Following my complete restore this morning I received a response to my question on the Adobe forum and if anyone has this similar issue in the future then try this. Someone said it worked for them that was having this problem.
"Maybe there are some flash-based softwares installed in your machine conflict with Extension Manager. You can try to move all files under "C:\Users\<YourUserName>\AppData\Roaming\Macromedia\Flash Player\#Security\FlashPlayerTrust" to somewhere, then launch Extension Manager. If it worked, You can move those files back one by one to isolate the software which causes this issue."
CraigRBeta Tester
..too late for you
I remember seeing this post and, after just experiencing the same problem myself, found the fix on the adobe site.
Hoping I could help you before you took more drastic measures, however I can confirm...
deleting the flashfirebug.cfg then rebooting, does indeed fix the problem
a2d
Craig, I was lucky I had a backup I could restore from
Took about 5 hours to restore but I'm glad I didn't have to completely uninstall my adobe suite and lose all my actions, brushes and other extensions and have to re-install them again. Would have been a whole lot easier to just delete that flash file and if I waited one more day I would have found the solution from an adobe user's post. Thanks for keeping me in mind!
