CSS Menu Writer won't create a menu
Thread begun 9/11/2011 10:14 am by ken_ww422171 | Last modified 9/12/2011 9:06 am by ken_ww422171 | 1753 views | 2 replies |
ken_ww422171
I just downloaded the CSS-Design Suite. When try to insert a new menu, the extension trys to load, it hangs up for a while, then tells me the:
CSSMenuWriter/WA_SitePreferences.js has been running for a long time. Do you want to continue?
I tell it no, then the extension loads. I try to insert a new menu, or a select new menu attribute, but it hangs up the same way.
I have uninstalled and reinstalled the extension twice.
I am on a pc, running windows XP
CSS Menu Writer did work the first time I tried it, but I haven't been able to get it to work since. Any suggestions?
this issue will occur if you do not define a testing server in your Dreamweaver site definition.
Make sure that your Dreamweaver site definition has a testing server configured in the Servers section, if you only use one server as the remote server, select the remote server to be both remote and testing.
ken_ww422171
CSS Menu Writer
Thank you!!! I spent several frustrating hours trying to make that work. I wish that bit of information had been in the documentation. If it was, I did not see it.
Anyway, thank you!
