display of non english characters
Thread began 9/09/2011 3:12 am by CraigR | Last modified 9/09/2011 11:09 am by CraigR | 1169 views | 2 replies |
CraigRBeta Tester
in my pursuit of a multi-language site, some of my text is static and is presented to my php page via an includes file, and some text is retrieved from the database.
on my local testing server, both appear as normal, but on my client site, the static text appears fine, but the database text is not.
My php page is encoded as utf-8 and so is the database field.
Viewing the database table in each instance via phpmyadmin shows the text correctly
On the image, the menu text (with the blue background) appears fine.
I have been reading up about the activation of multibyte strings in php.ini.
I know this is active on my machine, could this be a reason why the static text is ok and database provided text is not, or is this throwing me off the scent ?
most likely, you just need to set the character set to be used for the Database connection.
in the database connections file, add the following code at the end:
<?php if (!function_exists('mysql_set_charset')) {
     function
mysql_set_charset($charset$link_identifier null)
         if (
$link_identifier == null) {
             return
mysql_query('SET NAMES "'.$charset.'"');
         } else {
             return
mysql_query('SET NAMES "'.$charset.'"'$link_identifier);
mysql_set_charset('utf8',$<yourConnectionName>);
where <yourConnectionName> is the name of your connection file.
CraigRBeta Tester
Fantastic !!
Been going around in circles with this.
That fixed it.
Friday night now, and you just helped make the weekend.
Thanks Jason
