Multiple Record not updating....
Thread begun 8/27/2011 2:51 pm by Jim E D | Last modified 8/29/2011 10:45 am by Ray Borduin | 1611 views | 1 replies |
Jim E D
Not sure whats going on here, but the attached file worked at one point and stopped when I switched from my local wamp server to my host. Now I can't even get it to work on my wamp server. Here's what I did, reinstalled in DA, started over 6 times from scratch (got a couple to work - generally they would only post categories that were in a row and not the non-contiguous ones.
Followed the instructions and still know success. I'm sure it's my poor php skills.
You have a redirect page specified in the update server behavior that will prevent the multiple insert code from running. You should probably update line 58 to not specify a redirect page.
Also, it looks like an update page, so you should probably be using "manage relational table" and not "multiple insert" as the server behavior. I'd still try removing the multiple insert code and change it to manage relational table.
