Follow Up Questions: For my Premiere Ticket
Thread begun 8/23/2011 10:46 pm by Sly Verano | Last modified 9/30/2011 7:57 am by Jason Byrnes | 6300 views | 9 replies |
Sly Verano
Hi Guys,
How can i display who's comment is that and the profile picture of the one who comment to that
profile page, and also displaying the date and time of that of the comment. another is how can i add a REPLY
to that particular comment.
Because Ray only teach me the basic, how to display the user's comment to that profile page.
Thanks.
In the comments table, you should have a column that relates the comment to the user that posted it. You would need to create a join query to return the users information, along with the comment.
I dont know the structure of your users table of the structure of your comments table, so cannot giver you the exact SQL query to use, but it would be something along the lines of:
SELECT users.firstName, users.lastName, users.profilePic, comments.*
FROM comments
INNER JOIN users ON comments.userID = users.userID
then to display that on your comments page you can use the bindings panel to bind the userFirslt name and last name column, and add an image tag to show their profile picture:
<img src="path/to/images/<?php echo $row_RecordsetName['profilePic']; ?>" />
to show the date the comment was made, your comments table would need to have a date column that stored the date, then use the bindings panel to add the binding for the date just like the others.
Sly Verano
Hi Jason,
Thanks for the response. It's sounds clear into my mind now.
But, How could I do the REPLY to that comment ? Should I create another table which is
tbl_reply ? Or another field for the comment table ?
Thanks in Advanced.
in the comments table you would need to a reply column, and a primary key column.
if it is a regular comment, set the value of the reply column to 0. if it is a reply comment, set the value of the reply column to the ID from the primary key column for the comment that is being replied to.
Sly Verano
Okay Thanks Jason,
Just let me clarify it.
In my comment table I will also add reply column and another primary key for that reply column. Right ?
So therefore their are two primary keys in the comment table. The first is the comment_id and the second is the reply_id. Right ?
Yes it is a reply comment, but what do you mean I will set the value of the reply column... blah blah blah ... ? Can you elaborate it well. I didn't understand what to do want to tell.
Thanks in Advanced Again ... :)
no, only one primary key column in the table, not 2.
in the replyID column, you will store the value from the primary key column of the comment it is a reply to.
lets say you have a comment record where the comment_id column is "22"
to create a reply to that comment, in the new comment record that is created, the replyId column will get the value "22"
the reply ID column is used to tell it which comment the reply relates to.
Sly Verano
Oh I see. Thanks a lot.
but how could the reply_id column get the value of "22" ?
Thanks In advanced Again.
you would need to have a hidden form element, set the hidden form element to the value of the parent comment, when the reply button is clicked, trigger an insert record behavior to insert the reply comment.
In the insert record behavior, set the reply_id column to use the value from the hidden form element.
Sly Verano
Hi Jason,
I already have my recordset to view the comment and it's already on a repeat region,. and
now I will create the reply to that comment. my problem is when I attached a new HTML
Editor inside that repeat region. THe html editor did'nt repeat ... only at first comment
contains the new HTML Editor and the rest of the comments doesn't have that new
HTML Editor that I attach (the new HTML Editor is for my Reply to Comment)....
can you teach me what is the proper set-up in building a reply to comment ...
Thanks a Lot
the HTML Editor should not be in a repeat region.
next to each comment, you would have a link to another page to replay to it. This link will send the comment ID as a querystring variable.
on the next page, have the HTML Editor text box to enter the reply, and a hidden form element that is set to capture comment ID form the querysting.
in the insert record behavior, set the reply_id column to use the hidden form element. and the comment column to use the HTML Editor instance.
