I have to be missing something fundamental
Thread begun 8/23/2011 7:27 am by info105077 | Last modified 10/22/2015 12:20 pm by Ray Borduin | 2389 views | 4 replies |
info105077
Hi Guys I need a little urgent help
I am creating a shoe shop where one table holds a record of the shoes and another holds the sizes of each shoe along with various other info. My results page links with the detail page via the shoe_products_ref column which is a 'view' of the combined tables.
No problem there... So i create my cart with extra columns for size and barcode and I can even create the cart page with the correct size chosen from a dynamic list.
My problem is that it's not carrying forward any of the data that is unique to each shoe ie the
shoe_size_id, shoe_size, barcode_ref, shoe_price etc it always just takes the first instance of shoe according to the column shoe_product_ref.
I have to be missing something fundamental.
attached is a db plan, the 'view' and the renamed view as a recordset used by the cart
the results page is: shoe_products_Results.php
the detail page is eg: shoe_products_Detail.php?shoe_product_ref=B003
and the cart page: cart.php
Many thanks in advance for any help offered
Russ
you would need to create a second lookup recordset to lookup the information for the selected size:
rsSizeLookup
SELECT *
FROM shopshoes
WHERE shoe_product_ref = colname AND shoe_sizes_and_colours.shoe_size = paramSize
ORDER BY shoe_size ASC
type:text
default value: -1
runtime value: $_GET['shoe_product_ref']
type:text
default value: -1
runtime value: $_POST['eCart1_1_Size_Add']
then in the add to cart button, bind the columns that need to get the selected size info to the columns from the new rsSizeLookup recordset.
info105077
Thank you Jason that certainly fixed this stage
Russ
anonymous
Originally Said By: info105077
Russ
what role is the barcode playing in this filed?
anonymous
I wonder have you worked it out? when it comes to barcode problem, I wonder which kind of
barcode scanner were you using? I am also looking for a fine toolkit to help me read barcode these days. It wiil be better if it offers free trial package for users to check. Any suggetsion will be appreciated. Thanks in advance.
Best regards,
Pan
