Monogramming
Thread begun 7/12/2009 12:33 pm by JBWebWorks | Last modified 7/13/2009 4:28 pm by JBWebWorks | 6323 views | 9 replies |
JBWebWorks
Monogramming
I have a store with items populated by recordset and item option of color choice populated by a different recordset.
Items can be monogrammed and the options are font choice, thread color and initials or name to be filled in by the shopper. Monogramming is an additional charge of $5
I am not sure how to set this up.
either or?
1-database lookup of options just like the color choice (but then how to get the $5 charge to the cart)
2-set up monogramming as an item (but where the shopper can bind it to their item choice)
here is a sample page, but without any monogramming choice.
aprons.php
JBWebWorks
I am able to get the monogramming options from the product page to the cart, but i am trying to add the $5 charge for each item that is added with monogramming options.
I have tried several variations under the charges tab of the eCart Object but without success?
any advice on how to do this?
How are you adding them?
If you added a column called "Monogram" and it will be either blank or have a value if it has a monogram, then you can use a calculation like:
TruePrice = [Price] + (([Monogram]=="")0:5)
and Update:
TotalPrice = ([Price] + (([Monogram]=="")?0:5)) * [Quantity]
JBWebWorks
thanks Ray
entering that info with a column named fonts
i get this error when trying to view the product page in browser
Parse error: syntax error, unexpected T_LNUMBER in C:\vhosts\elitestitches\WA_eCart\elitestitches_PHP.php on line 10
the lines from elitestitches_PHP.php in question are
$itmObj->TotalWeight = $itmObj->Weight * $itmObj->Quantity;//w
$itmObj->TotalPrice = ($itmObj->Price + (($itmObj->fonts=="")0:5)) * $itmObj->Quantity ;//c
$itmObj->FullDetails = $itmObj->Quantity . ' ' . $itmObj->Name . ' (' . $itmObj->ID . ')';//t
$itmObj->TruePrice = $itmObj->Price + (($itmObj->fonts=="")0:5);//c
I had a typo... should be a "?" before the 0:5... I updated my original example.
JBWebWorks
Great Ray
that works and adds the $5 charge only for the items added with monogramming and doesn't add the $5 if no monogramming is requested.
it shows the item price as say $38 and then the total $43.
I am wondering if i can denote Monogramming Charge $5 somewhere on the item on the cart for an item with monogramming requested?
You could display [TruePrice] instead of price and just show the total price, or you could add a calculation:
MonoPrice = (([Monogram]=="")?0:5)
and display the MonoPrice column
JBWebWorks
thanks again Ray
if i could ask another question.
I have 3 unique columns, fonts, threadcolor and initials and the shopper requests the font and the thread color from a select list and fills in the initials in a text field all in the add to cart form. i have a <div> tag around the select lists and the text field.
I was wondering if in PHP can you write if/else to show these forms only if an item can be monogrammed?
I tried to use DW tag behaviors, but it would only work on the 1st item listed in the repeat region?
You could write an IF statement in PHP... The div neither helps nor hurts in this process.
JBWebWorks
It worked.
wrote this before the <div>
if ($row_rs_itemcat['itemActive']=="Monogramming Available!"){ ?>
and this after
<?php } ?>
and any item with Monogramming Available! in the itemActive column shows the fonts,thread and initials form elements while any item with a blank in itemActive column shows nothing.
Ray,
thanks very much for your help
