Redirect after insert using DA failing
This issue (unless a coincidence) has occurred after what i thought was a fix for a similar issue reported here:
http://www.webassist.com/forums/showthread.php?t=22165
After inserting a new record I was getting a blank page showing the following instead of redirecting to my confirmation.php page
(it was working fine until i made the above modification that fixed my first issue)
Strict Standards: date() [function.date]: It is not safe to rely on the system's timezone settings. Please use the date.timezone setting, the TZ environment variable or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/London' for 'BST/1.0/DST' instead in /home/www/crazyplumhomes.co.uk/register/register.php on line 99
Strict Standards: date() [function.date]: It is not safe to rely on the system's timezone settings. Please use the date.timezone setting, the TZ environment variable or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/London' for 'BST/1.0/DST' instead in /home/www/crazyplumhomes.co.uk/webassist/email/mail_php.php on line 198
Fatal error: Cannot redeclare wa_ab_getloopedfieldname() (previously declared in /home/www/crazyplumhomes.co.uk/WA_DataAssist/WA_AppBuilder_PHP.php:11) in /home/www/crazyplumhomes.co.uk/webassist/database_management/wa_appbuilder_php.php on line 19
I've since fixed again.
Does anyone know what and why this being caused?
Thanks,
