Not showing a 'thanks' page after email triggered
Thread began 8/02/2011 3:25 pm by Paul | Last modified 8/06/2011 12:59 pm by Daryl | 2665 views | 7 replies |
PaulBeta Tester
I'm using DA and UE4 to insert a new members record and email a confirmation back to the new member on completion.
All works fine right up-until the point where UE sends the email, but hen fails to load my thanks.php page. I just get a blank page as if its stalled.
Attached is the register page.
Would it be possible for you to take a look to see if ive missed something?
Thanks, Paul.
register.zip
most likely, the problem is the blank lines between code blocks at line 114 and 117. lines 113 - 118 are:
<?php require_once("../webassist/email/mail_php.php"); ?>
require_once("../webassist/email/mailformatting_php.php"); ?>
it should be:
PaulBeta Tester
Thanks for your response.
I removed the space, but made no difference.
Prior to using DA to insert a new record, i was using DW's insert script, as per below. That worked fine and returned the 'thanks.php' page fine
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "WAATKRegistrationForm")) {
$insertSQL sprintf("INSERT INTO member_tbl (mem_email, mem_password, mem_app_dated, mem_fname, mem_lname, mem_type, mem_active, mem_conf_id, mem_active_flag, mem_terms, mem_host, mem_browser, mem_referrer, mem_picLimit) VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s)",
GetSQLValueString($_POST['mem_email'], "text"),
GetSQLValueString($_POST['mem_password'], "text"),
GetSQLValueString($_POST['mem_app_dated'], "text"),
GetSQLValueString($_POST['mem_fname'], "text"),
GetSQLValueString($_POST['mem_lname'], "text"),
GetSQLValueString($_POST['mem_type'], "int"),
GetSQLValueString($_POST['mem_active'], "int"),
GetSQLValueString($_POST['mem_conf_id'], "text"),
GetSQLValueString($_POST['mem_active_flag'], "int"),
GetSQLValueString($_POST['mem_terms'], "int"),
GetSQLValueString($_POST['mem_host'], "text"),
GetSQLValueString($_POST['mem_browser'], "text"),
GetSQLValueString($_POST['mem_referrer'], "text"),
GetSQLValueString($_POST['mem_picLimit'], "int"));
mysql_select_db($database_Crazyhomes$Crazyhomes);
$Result1 mysql_query($insertSQL$Crazyhomes) or die(mysql_error());
$query_RegType "SELECT * FROM mem_type WHERE mem_type.active=1";
$RegType mysql_query($query_RegType$Crazyhomes) or die(mysql_error());
$row_RegType mysql_fetch_assoc($RegType);
$totalRows_RegType mysql_num_rows($RegType);
My initial problem started just as soon as i switched the DW script for the DA version. everything else on the page was untouched
The registration page completes all the tasks right through to sending the email correctly, so i'm puzzled as to why the problem is occurring at some point between the email send and executing the $GoToPage = "thanks.php"; line, when i changed the insert script!
usually, if the redirect is not working it is due to a php error, add the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
PaulBeta Tester
Jason, thanks for hint.
following is page output:
Fatal error: Cannot redeclare wa_ab_getloopedfieldname() (previously declared in /home/www/crazyplumhomes.co.uk/WA_DataAssist/WA_AppBuilder_PHP.php:11) in /home/www/crazyplumhomes.co.uk/webassist/database_management/wa_appbuilder_php.php on line 19
Im not making much sense of it!
Any ideas?
Thanks, Paul
DarylBeta Tester
Your answer to that error is here Paul showthread.php?t=19580&highlight=Fatal+error%3A+redeclare
PaulBeta Tester
Cheers Daryl,
Well howabout that
I feel i can move on now!
Paul.
DarylBeta Tester
No problem Paul
I was sure I had the same problem a while ago.
