nothing happens when I click register
Thread begun 8/03/2011 8:45 am by sfurley1983390133 | Last modified 8/09/2011 11:59 am by Jason Byrnes | 5153 views | 7 replies |
sfurley1983390133
Hi I have uploaded the pages for the user solution pack to users_Registration.php
just to at least test it and nothing happens, I'm sure this should be straight forward any ideas What I have missed?
Thankyou in advance for your support...
it looks like you have removed the capcha security image and the security question form elements, you also deleted the honeypots hidden form elements, the fax, and the country.
if you remove these elements, you will also need to delete the code that validates them.
make sure to delete the following lines of code:
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_code"]))?strtolower($_POST["Security_code"]):"") . "",((isset($_SESSION["captcha_1"]))?strtolower($_SESSION["captcha_1"]):"") . "",true,7);
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_question"]))?strtolower($_POST["Security_question"]):"") . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,8);
$WAFV_Errors .= WAValidateRX(((isset($_POST["addblock"]))?$_POST["addblock"]:"") . "","/^$/i",false,9);
$WAFV_Errors .= WAValidateRX(((isset($_POST["secondblock"]))?$_POST["secondblock"]:"") . "","/^$/i",false,10);
$WAFV_Errors .= WAValidatePN(((isset($_POST["UserFax"]))?$_POST["UserFax"]:"") . "",false,true,false,14);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["UserCountry"]))?$_POST["UserCountry"]:"") . "",true,19);
if there are other form elements you have removed as well, you will need to finde the lines that validate those elements too.
sfurley1983390133
Ok thanks I managed to get the code to work now using users_Registration.php
however a when it goes through to verification it doesnt show
users_Confirm.php?ID=2&code=TfyR7xEluJRxdRyKGgw6
but does if you add
where would I add that in the code?
Thanks again, much appreciated...
in the WA_Globals.php file, make sure the root URL is set to:
UserRegistration100/
sfurley1983390133
Perfect that all works fine now, thank you very much for your help now I just have to incorporate my design around it, thanks again :-)
sfurley1983390133
Hi again, I have sorted and setup all pages, one small query, is there any way I can use locked web pages with power CMS
heres the code I have at the top of the page
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
if (!WA_Auth_RulePasses("Email Confirmed")){
WA_Auth_RestrictAccess("users_Profile.php");
<?php include "Connections/localhost.php"; ?>
<?php include "WA_CMS/WA_CMS.php"; ?>
and the page is here
protected_Page.php
to check username: stevelearners@gmail.com
password: password1
thanks again in advance
steve
sfurley1983390133
Also sorry one last thing, whats the code to add login and logout on each page near the top? Thanks again much appreciated.
you can use power cms content on security assist protected pages, but you will need to edit the WA_CMS/WA_CMS.php file to corewct a conflict, see the following thread:
showthread.php?t=15730
to add a login /logout link, use the following code:
<?php if(!WA_Auth_RulePasses("Logged in to users")){ ?>
<a href="users_LogIn.php">Log In</a>
<?php }?>
if(WA_Auth_RulePasses("Logged in to users")){ ?>
<a href="users_Logout.php">Log Out</a>
<?php }?>
