Security Assist and Css Sculptor sizing issue with forms
Thread begun 7/27/2011 2:17 pm by rg353713 | Last modified 7/28/2011 11:14 am by Jason Byrnes | 2602 views | 3 replies |
rg353713
Hello,
2 Questions:
1. I am using CSS Sculptor and have a 2 column site with the right as the thinner of the 2 along with a header, top navigation and a footer. I have made the width an even 1000px. The right column is 250px and the left is 750px.
When I apply this template to the login or registration page and put my content on the left side via an editable region its to wide and will not allow the columns to line up. If I add content to the right side it forces the log in or registration information on the left side to move down rather than lining up horizontal.
How do you make the form widths smaller so they do not overlap and stop the columns from lining up?
2. In security assist how can you disable the feature so if someone clicks in a login or password box then clicks away that it does not post the error please enter a value instantly?
Thanks,
Robert
1) there is most likely a css class that needs to have an overflow: hidden property added, if you could post a link, I could find out for sure.
2) near the bottom of the page is a javascript block that creates the spry validation. Removing that script will prevent the errors. once i see the page in the browser, I can tell you exactly what code needs to be removed.
rg353713
Here is the link to the pages.
login.php
registration.php
Thanks,
Robert
in the CSSSculptor/2ColumnFixedRightSidebarHeaderandFooter_CaboSunset_css/screen.css file, checnge:
#outerWrapper #contentWrapper #content {
margin: 0 220px 0 0;
padding: 10px;
width: 708px;
padding: 10px;
width: 708px;
overflow: hidden;
on the login page, the follokwing code initializes the spry validation:
var Log_In_group_Email_Spry = new Spry.Widget.ValidationTextField("Log_In_group_Email_Spry", "email", { minChars:6, maxChars:500 , validateOn:["blur"]});
var Log_In_group_Password_Spry = new Spry.Widget.ValidationPassword("Log_In_group_Password_Spry", { minAlphaChars:3, maxAlphaChars:500, minNumbers:2, maxNumbers:500, minSpecialChars:0, maxSpecialChars:0, minChars:6, maxChars:500, isRequired:true , validateOn:["blur"]});
</script>
delete that, it will be similar code on the registration page.
