Upload PDF fails in CMS
Thread begun 7/25/2011 8:05 am by Erikk D. Lee | Last modified 7/26/2011 7:52 am by Ray Borduin | 2533 views | 7 replies |
Erikk D. Lee
I have been working to fix an issue with the file upload feature in PowerCMS. I can upload an image without issue however when I try and upload a PDF document it gives me the error "Invalid file type".
The fix in the past was to edit the config.php file and add pdf to the list however this did not work.
Here is the info I used.
Edit.. config.php file at HTMLEditor > editor > filemanager > connectors > php:
Update PHP Code and add pdf to the list.. : $Config['AllowedExtensions']['Image'] = array('bmp','gif','jpeg','jpg','png', 'pdf') ;
Not sure what to check next to resolve this issue.
Any ideas???
It looks like you are using an older version of the extension, since that isn't how it works any more. If you send me a copy of the file you updated I can take a look.
It is possible the file is too large to upload... have you tried a really small .pdf file? It also seems like that might be the wrong place to update. I'd have to look, but it should have a
$Config['AllowedExtensions']['File'] section I believe. .pdf is not an image file type, so that might be part of it as well.
Erikk D. Lee
Small test document its 552k I dont think its size.
Here is the config file that we edited.... Edit.. config.php file at HTMLEditor > editor > filemanager > connectors > php:
<?php require_once ("../../../../../WA_Globals/WA_Globals.php" ); ?>
* FCKeditor - The text editor for Internet - www.fckeditor.net
* Copyright (C) 2003-2009 Frederico Caldeira Knabben
* == BEGIN LICENSE ==
* Licensed under the terms of any of the following licenses at your
* choice:
* - GNU General Public License Version 2 or later (the "GPL")
* gpl.html
* - GNU Lesser General Public License Version 2.1 or later (the "LGPL")
* lgpl.html
* - Mozilla Public License Version 1.1 or later (the "MPL")
* MPL-1.1.html
* == END LICENSE ==
* Configuration file for the File Manager Connector for PHP.
global $Config ;
$WA_EditorLocalRoot = $WAGLOBAL_localRoot;
$WA_EditorRemoteRoot = $WAGLOBAL_remoteRoot;
$WA_curURL = strtolower((isset($_SERVER["PHP_SELF"]))?$_SERVER["PHP_SELF"]:"");
$EditorAssumedRoot = $WA_EditorRemoteRoot;
if ((strpos($WA_curURL,strtolower($WA_EditorLocalRoot)) !== false && strpos($WA_curURL,strtolower($WA_EditorLocalRoot)) == 0) && (strlen($WA_EditorLocalRoot) >= strlen($WA_EditorRemoteRoot) || strpos($WA_curURL,strtolower($WA_EditorLocalRoot)) === 0)) {
$EditorAssumedRoot = $WA_EditorLocalRoot;
// SECURITY: You must explicitly enable this "connector". (Set it to "true").
// WARNING: don't just set "$Config['Enabled'] = true ;", you must be sure that only
// authenticated users can access this file or use some kind of session checking.
// Path to user files relative to the document root.
$Config['UserFilesPath'] = 'files/' ;
$Config['UserFilesPath'] = $EditorAssumedRoot.$Config['UserFilesPath'];
// Fill the following value it you prefer to specify the absolute path for the
// user files directory. Useful if you are using a virtual directory, symbolic
// link or alias. Examples: 'C:\\MySite\\userfiles\\' or '/root/mysite/userfiles/'.
// Attention: The above 'UserFilesPath' must point to the same directory.
$Config['UserFilesAbsolutePath'] = '' ;
if (isset($_SERVER['APPL_PHYSICAL_PATH'])) {
$Config['UserFilesAbsolutePath'] = str_replace("\\","/",$_SERVER['APPL_PHYSICAL_PATH']) . substr($Config['UserFilesPath'],1);
// Due to security issues with Apache modules, it is recommended to leave the
// following setting enabled.
$Config['ForceSingleExtension'] = true ;
// Perform additional checks for image files.
// If set to true, validate image size (using getimagesize).
$Config['SecureImageUploads'] = true;
// What the user can do with this connector.
$Config['ConfigAllowedCommands'] = array('QuickUpload', 'FileUpload', 'GetFolders', 'GetFoldersAndFiles', 'CreateFolder') ;
// Allowed Resource Types.
$Config['ConfigAllowedTypes'] = array('File', 'Image', 'Flash', 'Media') ;
// For security, HTML is allowed in the first Kb of data for files having the
// following extensions only.
$Config['HtmlExtensions'] = array("html", "htm", "xml", "xsd", "txt", "js") ;
// After file is uploaded, sometimes it is required to change its permissions
// so that it was possible to access it at the later time.
// If possible, it is recommended to set more restrictive permissions, like 0755.
// Set to 0 to disable this feature.
// Note: not needed on Windows-based servers.
$Config['ChmodOnUpload'] = 0777 ;
// See comments above.
// Used when creating folders that does not exist.
$Config['ChmodOnFolderCreate'] = 0777 ;
Configuration settings for each Resource Type
- AllowedExtensions: the possible extensions that can be allowed.
If it is empty then any file type can be uploaded.
- DeniedExtensions: The extensions that won't be allowed.
If it is empty then no restrictions are done here.
For a file to be uploaded it has to fulfill both the AllowedExtensions
and DeniedExtensions (that's it: not being denied) conditions.
- FileTypesPath: the virtual folder relative to the document root where
these resources will be located.
Attention: It must start and end with a slash: '/'
- FileTypesAbsolutePath: the physical path to the above folder. It must be
an absolute path.
If it's an empty string then it will be autocalculated.
Useful if you are using a virtual directory, symbolic link or alias.
Attention: The above 'FileTypesPath' must point to the same directory.
Attention: It must end with a slash: '/'
- QuickUploadPath: the virtual folder relative to the document root where
these resources will be uploaded using the Upload tab in the resources
dialogs.
- QuickUploadAbsolutePath: the physical path to the above folder. It must be
an absolute path.
Attention: The above 'QuickUploadPath' must point to the same directory.
NOTE: by default, QuickUploadPath and QuickUploadAbsolutePath point to
"userfiles" directory to maintain backwards compatibility with older versions of FCKeditor.
This is fine, but you in some cases you will be not able to browse uploaded files using file browser.
Example: if you click on "image button", select "Upload" tab and send image
to the server, image will appear in FCKeditor correctly, but because it is placed
directly in /userfiles/ directory, you'll be not able to see it in built-in file browser.
The more expected behaviour would be to send images directly to "image" subfolder.
To achieve that, simply change
$Config['QuickUploadPath']['Image'] = $Config['UserFilesPath'] ;
$Config['QuickUploadAbsolutePath']['Image'] = $Config['UserFilesAbsolutePath'] ;
into:
$Config['QuickUploadPath']['Image'] = $Config['FileTypesPath']['Image'] ;
$Config['QuickUploadAbsolutePath']['Image'] = $Config['FileTypesAbsolutePath']['Image'] ;
$Config['AllowedExtensions']['File'] = array('7z', 'aiff', 'asf', 'avi', 'bmp', 'csv', 'doc', 'fla', 'flv', 'gif', 'gz', 'gzip', 'jpeg', 'jpg', 'mid', 'mov', 'mp3', 'mp4', 'mpc', 'mpeg', 'mpg', 'ods', 'odt', 'pdf', 'png', 'ppt', 'pxd', 'qt', 'ram', 'rar', 'rm', 'rmi', 'rmvb', 'rtf', 'sdc', 'sitd', 'swf', 'sxc', 'sxw', 'tar', 'tgz', 'tif', 'tiff', 'txt', 'vsd', 'wav', 'wma', 'wmv', 'xls', 'xml', 'zip') ;
$Config['DeniedExtensions']['File'] = array() ;
$Config['FileTypesPath']['File'] = $Config['UserFilesPath'] . '' ;
$Config['FileTypesAbsolutePath']['File']= ($Config['UserFilesAbsolutePath'] == '') ? '' : $Config['UserFilesAbsolutePath'] ;
$Config['QuickUploadPath']['File'] = $Config['UserFilesPath'] ;
$Config['QuickUploadAbsolutePath']['File']= $Config['UserFilesAbsolutePath'] ;
$Config['AllowedExtensions']['Image'] = array('bmp','gif','jpeg','jpg','png') ;
$Config['DeniedExtensions']['Image'] = array() ;
$Config['FileTypesPath']['Image'] = $Config['UserFilesPath'] . '' ;
$Config['FileTypesAbsolutePath']['Image']= ($Config['UserFilesAbsolutePath'] == '') ? '' : $Config['UserFilesAbsolutePath'] ;
$Config['QuickUploadAbsolutePath']['Image']= $Config['UserFilesAbsolutePath'] ;
$Config['AllowedExtensions']['Flash'] = array('swf','flv') ;
$Config['DeniedExtensions']['Flash'] = array() ;
$Config['FileTypesPath']['Flash'] = $Config['UserFilesPath'] . '' ;
$Config['FileTypesAbsolutePath']['Flash']= ($Config['UserFilesAbsolutePath'] == '') ? '' : $Config['UserFilesAbsolutePath'] ;
$Config['QuickUploadPath']['Flash'] = $Config['UserFilesPath'] ;
$Config['QuickUploadAbsolutePath']['Flash']= $Config['UserFilesAbsolutePath'] ;
$Config['AllowedExtensions']['Media'] = array('aiff', 'asf', 'avi', 'bmp', 'fla', 'flv', 'gif', 'jpeg', 'jpg', 'mid', 'mov', 'mp3', 'mp4', 'mpc', 'mpeg', 'mpg', 'png', 'pdf', 'qt', 'ram', 'rm', 'rmi', 'rmvb', 'swf', 'tif', 'tiff', 'wav', 'wma', 'wmv') ;
$Config['DeniedExtensions']['Media'] = array() ;
$Config['FileTypesPath']['Media'] = $Config['UserFilesPath'] . '' ;
$Config['FileTypesAbsolutePath']['Media']= ($Config['UserFilesAbsolutePath'] == '') ? '' : $Config['UserFilesAbsolutePath'] ;
$Config['QuickUploadPath']['Media'] = $Config['UserFilesPath'] ;
$Config['QuickUploadAbsolutePath']['Media']= $Config['UserFilesAbsolutePath'] ;
PDF files are already in the list:
so that isn't the source of the problem. Do other uploads work? Can you upload a .zip file or .txt file?
Erikk D. Lee
Other files can be uploaded with out issue. The PDF was not in the list we added it after reading past posts that show a fix... we said this in our first post.
You added it to the 'Images' list... which is not the right place. I see it is already in the 'File' list I've referenced in the previous post. Remove it from the 'Image' list where you added it. That could be doing more harm than good.
Erikk D. Lee
Ok.. pdf has been removed from the image list.
I've opened a support incident so we can have an engineer help you debug this.
