Can't login to CMS admin services
Thread begun 7/23/2011 1:30 pm by genelee2330761 | Last modified 7/25/2011 6:03 am by Ray Borduin | 1865 views | 1 replies |
genelee2330761
Here is a thread about the error message I was getting in the pages generated by Security Assist after I did the initial install for Power CMS Builder.
showthread.php?t=21919
This was the solution for that problem and this did work to get me into the Security Assist pages:
Delete the reference to: /WA_SecurityAssist/Helper_PHP.php
The new file: /webassist/security_assist/helper_php.php
BUT, after doing this I got a similar error message when I tried to go to the admin_cms/index.php file to start inputting content on a CMS controlled page. So, I went through all the files that had been generated by Power CMS Builder and changed the reference for the helper_php.php file to the new version.
Now I can get to the CMS admin page but my login/password don't work.
Is there an order in which I should implement various packages in the Power Suite so these kinds of conflicts don't happen? Or is there a newer version of Power CMS Builder that uses the newer file when it sets up its files?
The issue is that you now have two versions of the file:
helpergroupsrulesphp.php
You'll have to combine the code the /WA_SecurityAssist/helpergroupsrulesphp.php into the new /webassist/security_assist/helpergroupsrulesphp.php file.
If you send me a copy of both files I can help you combine them.
