Display total number of items in cart at top of page
Thread begun 7/22/2011 7:58 am by Steve E | Last modified 7/23/2011 8:48 am by Steve E | 4169 views | 6 replies |
Steve E
Hi I am trying to display the total number of items in the shopping cart at the top of every web page and I read a thread that refers to Quick Cart, how could I access this functionallity?
The post reply mentioned added the following code to the pages,
//WA eCart Include
require_once("WA_eCart/ycCart_PHP.php");
$ycCart->GetContent();
At the moment, this file does not exist in my WA_ecart directory.
Any advice would be appreciated
UPDATED
Following the post and a Google search I found this link
ec_ed_03.htm
Is there a way I can add this functionality, without scrapping my existing build, as my cart has been based on the default option for the cart?
ycCart_PHP.php is referring to the code you would add if your cart was named "ycCart" you would add a reference to the file associated with the shopping cart you are using.
So anywhere in that code you see ycCart you would actually put your shopping cart name.
To display the total number of items in the cart you could use:
<?php echo($[yourcartname]->TotalColumn("Quantity")); ?>
Steve E
Thanks Ray
I am rebuilding the cart at the moment with the Quick Cart feature, could we post pone the
support call regarding the Simple drop down select for Shipping until this time Monday please
Our support engineer currently working on incidents has added you to his skype contacts. Just IM him when you are ready on monday and see he is online and you can go from there.
Steve E
Hi Ray
The code you gave me is generating a code hinting will not work error in Dreamwever, I am using PHP 5.35
You have to replace [yourcartname] with your cart name.
Steve E
Hi Ray
Sorry I was in a rush last night, I had [MyCartName] where I should of had 'MyCartName'
removing the [] solved it thank you very much.
