Popup Window too small
When I try o insert a map thepop-up window is too small and I can't access the lower form setup data like post code.
Any help appreciated
Clive
Clive
Can you provide a screen shot of what you are seeing? That might help me understand what the issue is. It may just be that you need to increase your screen resolution.
Thanks for the repsonse Ray,
I've attached the screenshot.
I'm using CS3 under Vista
The Screen resolutionis 1680x 1050
but I get the same problem wwhen using my laptop screen with a resolution of 1280x800
Hope this helps
Clive
This looks like an incompatibility with large fonts.
Go to: Control Panel/Personalisation in your windows start menu and turn off large fonts. That should correct the problem.
I'll log this as a bug so that we can look into finding a more elegant solution that would allow large fonts in a future update.
