CSS Form Builder won't run
Thread began 7/17/2011 3:48 pm by genelee2330761 | Last modified 7/17/2011 7:50 pm by anonymous | 994 views | 1 replies |
genelee2330761
I have installed the Form Builder and updated the javascript per instructions to fix the know error problem but I am still getting the following error when I try to create a new form by going to: WebAssist->Forms->Insert New Form
The following JavaScript error(s) occurred.
Unable to open script file "E:\Program Files (x86)\Adobe\Adobe Dreamweaver CS5\ Configuration\Shared\WebAssist\RichTextEditor\iRiteShared.js"
(error 3).
I did install CS5 on the E: drive do to space considerations and when I look into the file tree for the above file I don't find a WebAssist folder under my installation of Dreamweaver CS5.
anonymous
The WebAssist folder is not in the actual Dreamweaver folder but rather the user library for application support.
Did you try deleting the Dreamweaver cache file yet? That is typically the cause of these errors: common_installation_issues.pdf
Best regards,
Brian
