Send SMS From Contact Form
Thread begun 7/15/2011 12:01 pm by mantisdigital387802 | Last modified 7/18/2011 8:34 am by Jason Byrnes | 4782 views | 3 replies |
mantisdigital387802
Does anyone know of a sms / text messaging service script that works well with the Contact Form Solution Pack. I have my site setup to send to multiple recipients selected by the user. The form works perfectly. I now want to send these messages to multiple phone numbers via sms.
Here is the code I have so far.
<?php require_once('./WA_Globals/WA_Globals.php');?>
<?php require_once("./WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("./WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
<?php require_once("./WA_Universal_Email/mail_PHP.php"); ?>
<?php require_once("./WA_Universal_Email/MailFormatting_PHP.php"); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$varCatSelect_get_email_addresses = "' '";
if (isset($_GET['varCatSelect'])) {
$varCatSelect_get_email_addresses = $_GET['varCatSelect'];
$varLocSelect_get_email_addresses = "' '";
if (isset($_GET['varLocSelect'])) {
$varLocSelect_get_email_addresses = $_GET['varLocSelect'];
mysql_select_db($database_Connection, $Connection);
$query_get_email_addresses = sprintf("SELECT * FROM advertisers WHERE catagory= %s AND location= %s", GetSQLValueString($varCatSelect_get_email_addresses, "text"),GetSQLValueString($varLocSelect_get_email_addresses, "text"));
$get_email_addresses = mysql_query($query_get_email_addresses, $Connection) or die(mysql_error());
$row_get_email_addresses = mysql_fetch_assoc($get_email_addresses);
$totalRows_get_email_addresses = mysql_num_rows($get_email_addresses);
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$WAFV_Redirect = "";
$_SESSION['WAVT_contact_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ(((isset($_POST["Contact_Name"]))?$_POST["Contact_Name"]:"") . "",true,1);
$WAFV_Errors .= WAValidateEM(((isset($_POST["Email_address"]))?$_POST["Email_address"]:"") . "",true,2);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["Comments"]))?$_POST["Comments"]:"") . "",true,3);
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_code"]))?strtolower($_POST["Security_code"]):"") . "",((isset($_SESSION["captcha_1"]))?strtolower($_SESSION["captcha_1"]):"") . "",true,4);
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_question"]))?strtolower($_POST["Security_question"]):"") . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,5);
$WAFV_Errors .= WAValidateRX(((isset($_POST["addblock"]))?$_POST["addblock"]:"") . "","/^$/i",false,6);
$WAFV_Errors .= WAValidateRX(((isset($_POST["seconddblock"]))?$_POST["seconddblock"]:"") . "","/^$/i",false,7);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
if ((($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST))) {
//WA Universal Email object="mail"
//Send Loop Once Per Entry
$RecipientEmail = "".($WAGLOBAL_Contact_Email_To) ."";include("./WA_Universal_Email/WAUE_contact_1.php");
//Send Mail All Entries
if ("index.php"!="") {
header("Location: thankyou.php");
// This script sends sms to multiple recipients
$URN = "urn:notify.soap.thesmsgatewaycompany.net";
$WSDL="http://thesmsgatewaycompany.net/pmws/services/TxTMessageService?wsdl";
$encoding = SOAP_DEFAULT_ENCODING;
//SOAP elements (don&#8223;t edit, and case sensitive!)
$SOAP_ACTION = "sendMessage";
$CTUSERNAME = "Username";
$CTPASSWORD = "Password";
$CTNICKNAME = "nickname";
$DESTINATION = "destination";
$MESSAGE = "message";
$RECIPIENT = "recipients";
$ADMINEMAIL = "adminEmail";
$SUBJECT = "subject";
$USER_ID = "USERNAME"; //your username at CellTrust
$NICKNAME = "NICKNAME"; //your nickname at Celltrust
$PASSWORD = "password"; //your password at Celltrust
//create user and password SOAP header elements
$UserHdr = new SoapHeader( $URN, $CTUSERNAME, $USER_ID, false);
$PassHdr = new SoapHeader( $URN, $CTPASSWORD, $PASSWORD, false);
//create SOAP body elements, add your destination phone number, and message here
$dialstring = array(array("deliveryType" => 0, "destination" => "14805551212", "firstName" => "John", "lastName" => "Doe", "carrierId" => "19"),
array("deliveryType" => 0, "destination" => "14805551213", "firstName" => "Judy", "lastName" => "Doe", "carrierId" => "19"),
array("deliveryType" => 0, "destination" => "14805551214", "firstName" => "Test", "lastName" => "Doe", "carrierId" => "19"));
$bodymulti = array($CTNICKNAME => $NICKNAME, $SUBJECT => "Test SMS Message", $MESSAGE => "Test SMS Message Multiple recipients", $RECIPIENT => $dialstring, $ADMINEMAIL = "");
//create SOAP client
$client = new SoapClient($WSDL, array('trace' => 1, 'exceptions' =>0));
//set SOAP headers
$client->__setSoapHeaders(array($UserHdr, $PassHdr));
//call web service single sms
$result = $client->__call("sendMessage", $bodymulti, NULL);
//very usefull for debug purposes
//show what was requested
var_dump($client->__getLastRequest());
//show gateways response
var_dump($client->__getLastResponse());
This following code copied from above contains a sample array of multiple phone recipients which I will pull from the database the same way I have done so with the catagory and locations in this example but Im not sure if these scripts are conflicting or what is the best way to make sure that they will work together. Or, if someone knows of a sms service or script that will work better. Ideally, I would like this script to work as I have already set up an account with this sms service for trial purposes.
Any help with this is greatly appreciated. Thank you
the universal email code:
is redirecting before the code that sends to the sms address.
change:if ("index.php"!="") {
if (""!="") {
header("Location: ");
to prevent the redirect.
mantisdigital387802
Thank you very much for your help with this.
Can the redirect be added after the sms script so the user will still be
directed to the thankyou.php page?
Also, the pages leading up to the contact form, I have mysql queries that fetch the catagory selection and locations from the database and display them in a do while loop then pass the variable to the following page based on the user selction. For the phone numers, I can fetch them from the database on the previous page the same way but how can that information be used to populate the dialstring array which is included in the script and not in the body of the page?
Just edited this post to include the question about creating the array of phone numbers to add to the sms script. Thanks.
I cant really help out with the custom scripting in this page, this is beyond the scope of the support we offer.
