Secure Certificate
Thread begun 7/13/2011 8:36 pm by anitah355532 | Last modified 7/14/2011 2:10 pm by Jason Byrnes | 1887 views | 3 replies |
anitah355532
Secure Certificate
Can you please tell me where I can turn off the requirement for checkout.php to use an SSL Certificate as my site is not using online payment and I have no need for one. I would like checkout.php to use http:// and not try connecting to https://
I figure that I need to make a change to webassist/globals/globals.php - somewhere amongst this:
$WAGLOBAL_Root_URL = (((isset($_SERVER['SERVER_PROTOCOL']) && strpos($_SERVER['SERVER_PROTOCOL'], 'HTTPS') !== false) || (isset($_SERVER['SERVER_PORT'])&& $_SERVER['SERVER_PORT'] == 443)) ? 'https://' : 'http://') . $_SERVER['SERVER_NAME'] . ( (isset($_SERVER['SERVER_PORT'])&& $_SERVER['SERVER_PORT'] != 80)?":".$_SERVER['SERVER_PORT']:"") . $assumedRoot;
mysql_free_result($WAGlobals);
Thanks, Anita
in the webassist/plugins/shopping_cart/checkout_form.php file, delete the following code:
if (empty($_SERVER['HTTPS'])) {
  $testRedirect = "https://".$_SERVER['SERVER_NAME'].$_SERVER['REQUEST_URI'];
  $c = curl_init();
  curl_setopt($c, CURLOPT_URL, $testRedirect);
  curl_setopt($c, CURLOPT_TIMEOUT, 90);
  curl_setopt($c, CURLOPT_SSL_VERIFYPEER, 1);
  curl_setopt($c, CURLOPT_SSL_VERIFYHOST, 1);
  $result = curl_exec($c);
  if ($result)  {
      header("location: ".$testRedirect);
      die();
anitah355532
Excellent ...... thanks Jason :-)
you're welcome.
