Removing parts of email body
Thread begun 7/06/2011 12:12 am by julie383376 | Last modified 8/11/2011 12:46 pm by Jason Byrnes | 6149 views | 11 replies |
julie383376
I don't know if I should post this in UE or DA, and I really don't know what I'm doing, so I can't even figure out what to search for to find my answer in the forum!
The problem is not with UE or DA working incorrectly, it's with me not knowing how to get the results I want...
I have set up logging on my form, and I have used the DA wizard to create results, detail, etc. pages. I need to remove some of the result information that displays for the Email Body field on the Detail page.
It begins with:
--WAMULTIBREAKWA Content-Type: text/plain Content-Transfer-Encoding: 8bit
Then it shows all content that is emailed but without formatting - all in a long paragraph - and ends with
--WAMULTIBREAKWA Content-Type: text/html
Then it shows the exact email that is sent - formatting and all - and ends with:
--WAMULTIBREAKWA--
I just need the data that was entered on the form... Am I going about this the wrong way?
I'm attaching a screenshot to better explain what I am getting and what I want.
Thanks for your help & patience!
~J
YellowCircleWeb
Hi Julie,
You should be able to edit the information entered into the email body through the UE extension. Have you built the form using Form Builder or did you develop it yourself and then use the universal email extension?
The getting started guide for UE should explain how to do this: universal-email_gsg.php
Hope this helps you
julie383376
First a disclaimer - I've used UE a lot, but never had to do anything more than send an email... I know very little about PHP, and what I do, I've learned from troubleshooting WA scripts ;)
I built the form myself a few months ago and used UE for emailing functionality only. In UE, I created a custom email reply form.
My customer just recently wanted to add this logging feature, so I used the existing UE binding to enable logging.
When I set up logging, I had to use the Create Email Message help file because the GSG gives *very* little information on the logging feature.
I first let the wizard create the table for me, then I went back in and changed the logging to insert a record on failure or success.
"Email Column" is tied to the EmailTo field.
In the large Field Values box, I clicked on each column field (except for EmailID and EmailDate) and clicked the lightning bolt to do the binding for each, matching them to the field displayed in [Current Email]. Those were:
Email To [To]
EmailFrom [From]
EmailSubject [Subject]
EmailBody [Body]
EmailHeader [Header]
EmailError [Error]
EmailStatus [Status]
I didn't make a selection in the Format dropdown list, because I don't have a clue what that is.
So am I including too much information? Was I supposed to only bind the EmailTo field?
Or am I doing this all wrong?
My emails are sending, and the data is collecting just fine. I just can't get the DA detail page to display the information the way I want it to appear. In the email body part, I only want the data that was entered in the online form. At some point if an email fails, my customer may want to be able to view the header, so I'm okay with all the information that is displayed for that field.
Ian H,
This is the email body that is being stored in the database by the email logging.
julie,
If all you want in the database is the dynamic form input, add the following at line 1 of your page:
if (($_SERVER["REQUEST_METHOD"] == "POST"))     {
session_start();
$_SESSION['mailBody'] = "";
    foreach(
$_POST as $pkey => $pval ){
$_SESSION['mailBody'] .= "".str_replace("_"," ",$pkey).": ".str_replace("\n","<BR />",(is_array($pval)?implode(", ",$pval):$pval))."<br />";
then go to the bindings panel, click the plus button and select Session Variable and name it "mailBody"
edit the universal Email instance, and go to the logging section. For the mail body column, click the lightning bolt next to value and select the mailBody session variable from the dynamic bindings.
julie383376
Wow... that looks WAY better!
Is it possible to change the way the new mailbody information looks? I want the results to be pretty ;)
Specifically, what I want to do is remove my captcha stuff at the end, and remove the field names (or make them invisible). Currently these are the last three lines of what I get:
comments: test
captcha x: 164
captcha y: 74
Now, just in case it matters, I didn't change anything on my DA pages, but they work fine, so I must not have needed to! I'm attaching a screenshot of new results.
sure, change the code at line 1 to:
session_start();
$removeArray = array();
$removeArray[] = "captcha_x";
$removeArray[] = "captcha_y";
    foreach(
        if(!
in_array($pkey,$removeArray)) {
$_SESSION['mailBody'] .= "".str_replace("\n","<BR />",(is_array($pval)?implode(", ",$pval):$pval))."<br />";
julie383376
You rock, Jason!
Thanks!
~J
no worries.
Nathan69474
Hi Jason,
I've a quirky add-on question ... I'm trying to do the same only with the Security Question / Answer rather then cachup
@session_start();
$removeArray[] = "Security_Answer";
$removeArray[] = "captcha_x"; // I've tried removing this, but still get the numbers
$removeArray[] = "captcha_y"; // as above
foreach($_POST as $pkey => $pval ){
if(!in_array($pkey,$removeArray)) {
The security answer correctly removes itself as does the field arrays but in the db I get an additional eg ... <br />33<br />4<br /> ... at the bottom of the db entry.
I've tested it 4 or 5 times and the 33's and 4's range from 33/35/38/39 or 4/11/12. There doesn't seem to a pattern to the numbers. The db entries numbers are 14-20 so it's not the emailID numbers, I've also compared it to the mins / seconds / date etc but again no pattern.
I'm guessing I need to add a couple of extra removes ... eg...
... $removeArray[] = "global_form_field_names";
It's only a basic form.
this is a typical full db entry (I've replace the form content inputs with the db field names)
contact name field<br />
email field<br />
phone number field<br />
company name field<br />
enquiry details field (followed by extra numbers)<br /><br />33<br />12<br />
It's not the most crucial of tidying ups but it would be nice to get id of the extra numbers.
nathan
send a copy of the page in a zip archive please.
