Originally Said By: Daryl
Personally I'm not keen on the presets that have been provided, I would prefer presets such as Mac, Jquery, Windows, Yahoo UI style buttons.
The current presets are presets specific to WebAssist and they are supported across the product line. The idea is that a user could generate for example... an entire set of security pages (login, email password, etc.) using SecurityAssist with the 'Inspiration' theme/preset, and then easily insert the same style of button to additional pages using CSS Button Styler.
I do like your suggestion for other commonly used button types to be included in the presets and I have passed that suggestion along.
When I tries to rename the preset I found that if I highlighted the name and tried to type I couldn't, but if I clicked at the end of the name and pressed delete I could then change the name. It would be slightly more intuitive to highlight then type (I think the other extensions that have presets work that way...).
This is because the preset name is highlighted when the Save Preset UI opens, but the field is disabled. After checking the 'Save as preset' option, focus in the UI is now set to that checkbox and not the preset name field. So delete, backspace, etc won't have any effect. I will look into the possibility of having a change of focus after checking 'Save as preset'.
I like the option to change your cursor types but there isn't a hand option, and I'm fairly sure you don't need all of the resize options. I'm not sure I would use the resize cursors, but if I would I would probably like to have more descriptive names rather than all the same.
I've logged this as an issue. We'll be removing duplicates and giving each e-resize option a unique name.
Maybe this is a bit picky for feedback, but that's what you get for not having any bugs that I tripped over :0)
This is a good thing! Thank you for the feedback, Daryl.
