Error finishing command: Process type "undefined" not found - URGENT
Thread began 6/07/2011 9:53 pm by Miguel | Last modified 6/30/2012 4:48 pm by Histteacher | 5315 views | 12 replies |
Miguel
Ugent! matter, since i got the new form toolkit and the security assist 2 everything has been mess up, i can not use CSS form builder all i get is this error:
The form builder just stays theres and builds nothing, i first thought it was cause of the template so i created a theme with framework builder and it gave me the same error, so i tested on a clean blank php page and again the same error.
I deleted every extention and installed everything once again following the order CSS formbuilder beta before html editor 3 then toolkit and so on to get the same error, this did not happened before i had Security assist 2 and the new form toolkit so im not sure wich of those 2 are messing everything up.
I also have deleted dreamweaver cache nothing works help im already out of date to gfinish this website huge mistake getting the SA2 in the middle of a project :confused:
Also the SA2 now doesnt even redirect to the right place it keeps loading the login page with a msg your logged, i know i can change the default page where to redirect but im trying to acces a page protected by SA2 unloged and when logged its not taking me there like the old SA1 :mad:
anonymous
Any word on this? I am getting the same error, as well.
Thanks,
Brian
This issue should be fixed in the new 2.0.1 update of Security Assist, the 2.0.1 update is available for download from the Download center page.
Make sure to uninstall the previous version before installing this newer one, and also, delete the Dreamweaver Cache file from the users configuration folder.
anonymous
Jason,
Thanks so much for the quick reply! I will give it a go.
Best regards,
Brian
No worries Brian.
anonymous
Hey Jason,
I am still having the issue even after uninstalling both Form Builder and HTML editor and the reinstalling them both.
I have a sneak suspicion that is related to the new HTML Editor since this only began happening after I installed it.
Brian
Willi Schneider
Same problem here
Hi Jason
Just installed CSS Form Builder and get the same problem.
Additional info:
I've made all precautions like deleting the dw_cache file, uninstalling universal email, installing in the right order etc....
DW CS4 on Win XP PRO SP3
In the extension manager CSS Form Builder version only shows as 2.0.0, although I've installed the SR1 Build
Greetings
Willi
