WA Server Validations shown twice
Thread began 6/06/2011 1:29 am by info4753 | Last modified 6/07/2011 11:27 am by Jason Byrnes | 1659 views | 5 replies |
info4753
If I open my login page, the WA Server Validations und Server Behaviours is shown twice. If I click on one of them the following error occurs:
If I double click on one of them, one disappears.
I feel like a beta tester ... :-(
see this thread you started on the same subject:
showthread.php?t=20933
info4753
No it's not the same problem, probably I didn't write it clear enough. When I open the page with the login form and have alook inside the DW Server Behaviours panel, then I see the Server Validation Behaviour twice added to the page. Please have a look at the attachment.
did you run the security assist wizard twice to create the same pages? This would double the code on the page.
When running the security assist wizard, if the page to create already exists, it will add the code for security assist to the existing code on the page, i you where to run it a second time, the code would be duplicated.
info4753
Not the wizard but I worked with the validation server behaviours. Maybe I got the wrong one. As mentioned in another thread, Valiadtion and Validation Toolkit have been both installed with DA2, SA2 and FB.
when you worked with the validation server behavior, did you insert a new one instead of editing the existing one?
to edit the existing server behavior, you open the server behaviors panel, then double click the server behavior to edit.
If you go to webassist -> forms -> Validation -> Server validation, this will insert a new instance of the server behavior instead of editing the existing one on the page.
