delete a record securely
Thread begun 6/03/2011 8:51 pm by dave315749 | Last modified 6/06/2011 6:57 am by Jason Byrnes | 4425 views | 9 replies |
dave315749
hello, i am setting up comments on my site for articles
delete behavior grabs id from a hidden form field in comment to find ID to delete. problem is, you could also post to that page from outside and delete any record with any id that way.
Whats a better way to set up a way to securely set up a delete server behavior function?
CraigRBeta Tester
What you do is control access to the delete page, so that only users with the appropriate rights can open the page.
Take a look at the security assist extension for more information.
securityassist/
dave315749
there is no delete page
well still a small problem.
1. there is no delete page it is right on the article page, you can add a comment or delete it..
2. if i have access to the page by a membership level or group, it would still be able to be deleted by another member...
CraigRBeta Tester
I would do this..
Have the delete button on the article page link to a delete page, (with the approprate security)
This also allows you to prompt the user with an 'are you sure you want to delete this'
and/or
Show / Hide the button on the article page, dependent on the login, so that if an admin is logged in , they can see the button, if a user (non admin) is logged in , they can't.
dave315749
Ok,
I guess i could have a popup ask if they are sure..
Only problem is, i would probably still want to do a manual query of the user id plus the comment, to make sure it matched.. and then proceed with the code right?
I made a test page and posted to that page with the code on it and it deleted the from the database.. Is there a easy way to modify the code for the delete server behavior so that it has to match 2 or more items in the database ( instead of just 1 key column) before deleting a record?
How about submit page plus a button behavior?
CraigRBeta Tester
The way I see it, if the user doesn't have the rights to access the delete option, there doesn't have to be any additional criteria for the delete server behavior.
I can't see a way to do this by accessing the Delete Record Server Behavior, though you may be able to hand code it.
I think you may need someone from Webassist to advise further
dave315749
Heres what i did
Craig,
I think i got it working now.
1. post the form using the ID of the comment
2. record set lookup finding ID and also matching the session ID of user who is logged in
3. set delete record trigger to if recordset is NOT EMPTY.
This way, the only person that could actually delete a comment, would have to be the same user ID logged in as the one who made it, i dont think anyone could post to the page from an outside and be able to delete any records..
does that look good to you?
CraigRBeta Tester
If you are know the id of the user logged in and it matches the id associated with the post, then the user should only be able to delete their own posts.
Same logic goes for editing too
dave315749
Yes
Yes but, the user might have made posts on other pages too, so the user would have multiple posts in the database, and therefore with a simple post, someone could delete anyones comment... so thats why i need more than one key column in the delete function.. or just do it the way with a trigger..
your articles table would need to have a column to associate the article to the user. when a new article is created, store the users ID value in that column.
then for the delete, create a recordset that would lookup the article ID and the Users ID, set the delete record behavior trigger to only happen if the lookup recordset is not empty.
