Javascript errors line 94 eCart5
Thread begun 6/01/2011 8:04 am by gzirfas374932 | Last modified 6/02/2011 11:47 am by Jason Byrnes | 1680 views | 2 replies |
gzirfas374932
I have everything built except the checkout. When I run the checkout wizard in CS5 I get a javascript error in CheckoutWizard.htm at line 94 in file eCart:ChWizJS:Orders.js:ActivePreset[0][x][0] has no properties. Which then shows a blank window. I tried it in CS4 and it opens the wizard but dies at the universal e-mail, which is activated in my extensions manager and works alone, but not with the wizard. So I can't do it in CS5 and I can't do it in CS4. I did the standard clearing the file cache and turning the extensions off and on again. Any other suggestions?
gzirfas374932
Supplied argument not valid MySQL link
Well, after complete delete and reinstall it finally worked. Got all the way thru, I think. It made my confirm page but no failure or success page. Don't know if I need those because I selected No payment gateway. However when I get to the confirm page it obviously is not connecting to the DB to store the order. Msg is: Warning: mysql_select_db();: supplied argument is not a valid MySQL-Link resource in /home/hemgen1/public_html/confirm.php on line 219 (and 253). Checked the DB and the tables for orders were created. Help.
eCart5, DW CS5
