No more wizard to edit the map
Thread begun 5/31/2011 3:25 am by fabrizioripesi426077 | Last modified 11/01/2011 1:51 pm by Jason Byrnes | 10003 views | 17 replies |
I have not more the property to modify the map. I press on the map but no wizard is possible. I have spry tabbed panels. In this forum I followed a thread to solve this problem but I have not solved. Can you help me?
send a copy of your page in a zip archive please, so I can take a look at the code.
Page
Here the page
Hi, did you solve the problem? Thanks
neilo
Dear Jim'll Fix It,
I can no longer re-enter the GUI to make adjustments to an existing map. I have been able to do so (I seem to remember) on previous occasions.
Have tried (same site) on DWCS5 and DWCS5.5 (waste of money that was) and on two different machines. This also involved having to reset all my activations on one of my accounts.
Seems there is no longer a way I can get in to modify a map. I have to create a new map every time I want to adjust something (that I can't do in the wagmp_map_X.php files). I now have about a dozen of the buggers.
Please could you fix this for me?
Many thanks.
When the map is inside the spry panel the panel takes priority and the map is not editable.
My only suggestion would be to temporarily move the div containing the map outside of the spry tabbed panel. Then you can edit the map and replace it back into the spry panel.
neilo
In my case, the map is not inside a spry panel. (Just for info!)
Is it inside some other translated area? Please send a url or attach a copy of the page and I'll see what might be causing the issue.
