Trouble Inserting Record with an Apostrophe
Thread begun 5/19/2011 5:20 am by vernon webb | Last modified 6/01/2011 12:42 pm by Jason Byrnes | 2002 views | 3 replies |
vernon webb
I've used DataAssist to setup an record insert however there are problems when one of those records has an apostrophe in it. How do I get around this?
~V
Can you provide a little more detail on the nature of the problem?
what happens to the apostrophe versus what you are expecting?
vernon webb
The content is split in different fields. For instance, a subject mind have "Jim's Mesaage" where this should be inserted into one record it is split after Jim pushing all content thereafter into the next field. Make sense?
hmm, I haven't run into that problem before.
Does the server have the Magic Quotes GPC setting turned on maybe? Magic Quotes GPC is a depricated function and should be disabled in the php settigns, contact the host to see if they can disable the magic quotes gpc setting for you.
