Users Registration Form
Thread begun 5/09/2011 3:48 pm by glozinski107205 | Last modified 5/10/2011 12:21 pm by Jason Byrnes | 3260 views | 5 replies |
glozinski107205
I have the Power Store 4.5 updated. I have this extension=php_gd2.dll unchecked, however, still cannot view this page as I believe it has something to do with the captcha and yet previous Power Store worked...I have also upgraded to CSS Form Builder 2.01 Beta and tehn upgraded HTML Editor 3.0....Not sure where to look next. thank you in advance
add the following code to line 1 of the registration page:
error_reporting
(E_ALL);
ini_set('display_errors','on'):
and send a link where I can see the problem.
glozinski107205
error_reporting
(E_ALL);
ini_set('display_errors','on'):changed to semicolon for it to work
error Fatal error: Cannot redeclare ValidatedField() (previously declared in C:\inetpub\wwwroot\ps4\WA_ValidationToolkit\WAVT_ValidatedForm_PHP.php:5) in C:\inetpub\wwwroot\ps4\webassist\form_validations\wavt_validatedform_php.php on line 21
here is the page
if (!session_id()) {
session_start();
function ValidatedField($page,$field) {
$theFields= "";
$retVal = "";
if (isset($_SESSION["WAVT_".$page."_Errors"])) {
$theFields = "&".$_SESSION["WAVT_".$page."_Errors"];
if (strpos($theFields,"&WAVT_".$field."=") !== false) {
$retVal = substr($theFields,strpos($theFields,"&WAVT_".$field."=")+strlen("&WAVT_".$field."="));
if (strpos($retVal,"&WAVT_") !== false) {
$retVal = substr($retVal,0,strpos($retVal,"&WAVT_"));
if ($retVal == "" && $page == $field) {
$retVal = ValidatedField($page,$field."_Errors");
return $retVal;
thank you
this error means that there are 2 lines on the page to include the wavt_validatedform_php.php file, remove one of them
glozinski107205
that did not work so I reinstalled the powerstore files and voila now having issues with Admin not saving...any suggestions
Thank you
See this post:
showthread.php?t=19887
