Which addon would allow CRUD to MySQL ?
Thread begun 5/03/2011 11:05 am by ibnsaeed425706 | Last modified 8/29/2019 2:49 am by anonymous | 5999 views | 7 replies |
ibnsaeed425706
Hello
I am looking for a very simple addon which would allow me to Insert/Update/Delete etc. records to my MySQL database within Dreamweaver without leaving Dreamweaver.
I am not looking for setting up an insert page and then add the records.
What i need is to have a Panel or an Object inside Dreamweaver which would allow me to add records to my CMS with a Visual Panel inside Dreamweaver, sort of a Floating Panel without ever touching a php file or any web file.
To Populate Data via a Panel rather than a php file.
I am not familiar with any extensions for Dreamweaver that will accomplish this.
ibnsaeed425706
Can you suggest any tutorial or a book where i can learn ?
you are asking about something that Dreamweaver is not capable of.
As far as I am aware, you cannot add data to the database from within Dreamweaver.
you would need to either create webpages using Dreamweaver to manage the data in your database, or use a MySQL GUI Tool like Sequel Pro, Navicat, or PHPMyAdmin to manage the MySQL database.
ibnsaeed425706
Thanks , that is why i was unable to find any info on the net or even an example of such a thing.
This clears up a lot of confusion.
You're welcome.
anonymous
When I think of the term CRUD, I think of ORM (object relation mapping) and active record where all four functions can be handled by the ORM - such as in Ruby on Rails.
anonymous
PHP CRUD App
This post has been deleted.
