Keyword search fix causes JavaScript Error
Thread begun 4/29/2011 12:13 pm by Dennis | Last modified 5/04/2011 7:03 am by Jason Byrnes | 2247 views | 3 replies |
Dennis
My Search, Results, & Details pages created with WA DA Wizard are working fine.
Here on the forums I read the key to searching multiple columns was to add a keyword search. After adding the keyword search to my Results page, the search resulted in no results.
In this thread... showthread.php?t=14905 reply # 18 by Jason has a suggestion that resolves my problem of No Results. After I applied the suggested code, the Search & Results pages work great. However after doing so I get a JavaScript error (related to keyword) whenever I try to reopen the DataAssist Search Server Behavior.
Dennis
Dennis
So others that are interested will know...
When I patched the code per the suggestion in the referenced link, I wanted to keep available the original code, in case I made a mistake typing. So I added a couple slashes "//" to the beginning of the original code thinking this would turn it into a comment.
This apparently caused the JavaScript error I was getting. Ray deleted the line of code and everything is working fine.
Thanks to the tech supt. folks.
Dennis
Glad to hear it is working.
