Using Styles with HTML Editor?
Thread begun 4/26/2011 7:37 am by Andrew Read | Last modified 4/26/2011 8:45 pm by Neil Beadle | 3637 views | 6 replies |
Andrew Read
Is there a tutorial for using the styles manager in HTML Editor 3.0.1?
Is there a way to import styles from a css file?
All of the available documentation for HTML Editor is on the HTML Editor Support page:
html-editor/
The getting started guide has a little info an using the styles tab, as does the help documentation:
styling.html
On the styling tab, click the plus button to add your style sheet.
then click the pencil icon next to "Modify the options listed in the Styles menu of the HTML Editor Toolbar" Then Click the Import button and select the styles that should be imported.
Andrew Read
I looked at the GSG, and frankly it is so simplistic that it is nearly useless. :)
This is quite a powerful and complicated product, and there is really no information available for it's users to figure out how it works.
I would love to be able to use this product to it's maximum potential, but in order for me to do so, WebAssist seriously needs to document this product and all of its features.
Neil Beadle
The Getting Started Guide is intended to help you "get started" with the product. It covers the more general aspects of the product but does not go into the specific detail of each interface.
This is why we include the built-in help for our extensions, which is the second link Jason provided. There is a page for each interface so if you are unsure of what to do, you should be able to get more information by clicking the Help button from the interface.
If you still need help after reviewing the documentation we have provided, then post your question to the forum. We do additional documentation if Support finds that there a lot of repeat questions on a particular feature.
-Neil
Andrew Read
Hi Neil,
Frankly I find the documentation lacking across the entire WA product range, but the more complex the product, the more frustrating the documentation is.
I (and I assume others) purchased these Extensions in order to save time and to become more productive. If I have to spend piles of time scouring the web and digging through help files that may or may not cover the parts of a product I am looking to use, then the benefit of the Extensions fades dramatically.
As an example, here are a few quick things that are not covered in the help file for HTML Editor:
1) First page of your wizzard click "Help" - What is covered by "Editor Preset(s)"? What functions can be found in there? If I don't know what is in there I am unlikely to go further and find the help that in need for those functions - one of which was the ability to link a style sheet to the HTML Editor instance.
2) Import styles list "Help" - There is no explanation here as to how one gets an existing css file to be linked to the HTML Editor which allows you to import styles, and even more strangely... this can not be done from this area!
3) The configuring styles list "Help" is very general, it doesn't explain what the different areas do in anything other than the most general sense. This is quite a complex area of the Extension (and frankly one that can make the Extension very useful) and it is barely touched on.
4) There is no indication in the GSG or anywhere in the help file as to how one would find the HTML Editor site settings which are buried within the WebAssist 'Forms' menu. Frankly I find WebAssist to have little elements scattered all over the Dreamweaver interface, and I find it frustrating to have to go digging through to figure out where to find each and every setting and option. For example - some of these types of settings are under the "Modify" menu item, some are under the "WebAssist" menu item, and yet others can be found under the "Preset Manager."
I hate to spend my time digging through menus to see if I can figure out where a setting can be changed, expecially when that info is NOT in the "Help" file or GSG.
5) I could go on, but I don't think that I need to. The documentation is lacking in detail and I know that I find this quite frustrating, I have to assume that others do as well.
I don't want to be completely negative, the products themselves have undergone major improvements over the past few years (I have been using them since the death of ADDT), it would be nice if the documentation and guides kept up with the rest of the improvements. What ever happened to the video guides, solution recipes, etc?
Andrew Read
Ahhh.. I remember what #5 was going to be... :D
5) The "File Upload" subdirectory (Editor Settings) - The help file does not explain what format the subdirectory should take. Is it "/subdirectory", "/subdirectory/", or simply "subdirectory"?
Neil Beadle
Andrew,
The Support individuals are not responsible for documentation and you should send your feedback or suggestions directly to the documentation team using the form found on this page: feedback.php?type=docs
The Support Engineers will assist you if you need help with a particular feature of a product that does not seem to be documented. You just need to ask.
-Neil
