PayPal Shipping Quote Failed
Thread begun 4/23/2011 9:19 am by mora398588 | Last modified 4/25/2011 10:51 am by Jason Byrnes | 2083 views | 3 replies |
mora398588
I ran a test using paypal to see if it was recognizing the weight column as 1 or 0 when determining if shipping is required for a particular item.
When running my test, I was adding one of our workshops to the shopping cart which has a value of 0 for determining shipping cost. 0 = no shipping fees.
What I got back was a shipping quote failed page. I attempted to go into my checkout page to see what I could do. What I did was I click on the Auth for paypal express checkout server behavior and scrolled down to the "ReqConfirmShipping" field and inserted the "weight" value from my eCart data.
I thought this would cause paypal to recognize the 1 or 0. This did not work. I even attempted to upload the PP_ECO_PHP file assuming that the changes may have taken place there and my server needed to be updated. This did nothing.
I know that paypal is attempted to determine if an item requires shipping, but it appears that it is getting confused between items that require shipping and those that do not. Now, when I last addressed an issue similiar to this, it was concerning Auth.net. That issue was successfully remedied. Would you be able to look at my attached file and determine what may be the problem.
Thank you!
It's not the paypal or authorize.net behaviors redirecting to the shipping failed page.
On the Confirm and pp_confirm pages, there is a behavior for either USPS, UPS or FedEx shipping rate lookup. Double Click that behavior and set the failed redirect to be blank.
mora398588
Jason, thank you for that bit of information. Your recommendation worked great!
glad to hear it is working.
