Remove button and quantity update not working in viewcart.php
Thread begun 4/15/2011 1:45 pm by BA | Last modified 4/19/2011 6:23 am by Jason Byrnes | 34042 views | 4 replies |
BA
I'm having two problems with the viewcart.php attached.
1) See code, line 359. The remove button simply does not work - it does nothing.
2) See code, line 358. The original page had the Quantity displayed as simple a figure (an echo statement) that could not be edited. I want the user to be able to change the quantity so I added the text input field from the eCart pallet and set the ID to Quantity. It works if you change the quantity and then click the update button, however, if you update the quantity and hit Enter, it totally empties the cart! Not what I expected. I'm pretty sure on other carts I've built it worked correctly to change the value and hit enter.
Can someone please advise?
the page you sent only goes to line 273, it does not include lines 359 and 358 referanced in your message.
From your description, when you added the cart display, you added a read only display, not an editable display.
When you add the eCart display manager, make sure to select the editable display option
as for the enter key functionality, the cart display form will submit the first button when you hit the enter key.
f you want the enter key to have a specific function, like updaing the cart, you will need to re arrange the code for the buttons:
<input type="submit" name="eCart1_Continue_100" id="eCart1_Continue_100" value="Continue Shopping" />
                  <input type="submit" name="eCart1_Clear_100" id="eCart1_Clear_100" value="Clear Cart" />
                  <input type="submit" name="eCart1_Update_100" id="eCart1_Update_100" value="Update" />
                <input type="submit" name="eCart1_Checkout" id="eCart1_Checkout" value="Checkout" /></td>
so that the update button is the first button:
BA
Sorry, I attached the wrong file. The correct one is attached now.
BA
I resolved the issue.
I identified the issue. The Remove checkbox was added with the Update_ function instead of the Delete_ function. You were correct in rearranging the submit buttons and with the Update first the page defaults on the enter key to do an Update.
Thank you!
OK, Glad to hear it is working.
