Searching Categories
Thread begun 4/11/2011 4:07 pm by hbibizadeh396670 | Last modified 4/12/2011 1:12 pm by hbibizadeh396670 | 2901 views | 3 replies |
hbibizadeh396670
Hi
I have made a directory. Although I have made the overall system work, I have a issue.
I have used data assist to make the results and detail pages.
I have made the directory using two database tables, one for categories and another for links.
When a user submits a link a menu dynamically lists all the values of the cat database, as a result the listings always have a category.
The problem is, on my pages I have a nav down the side set up dynamically to show the fields of the cat database.
The issue is I need to make the categories link to the results page to search for the cat clicked on.
If I just link to the page, all the results show when I only need the result for the selected cat to show.
Could you tell me how to do this please?
Thanks in advance
hbibizadeh396670
Is there a way of doing this?
hbibizadeh396670
Big ERROR with Data Assist
OK I made Part of it work.
I have made the results appear for the selected Category, by filtering a URL Paramiter
However it has caused a little issue with my overall system.
I need to filter the Recordset for two things, firstly the URL Par, but also to only show active listings.
When I try to add SQL manually I get an error
Is there a way of filtering the recordset for URL Par, and and entered value for the active listings.
hbibizadeh396670
I posted the question here to make it easier
showthread.php?t=19996
