Design Center Error
Thread begun 4/08/2011 2:30 pm by KiddaMan | Last modified 4/15/2011 2:44 pm by Dani Chankhour | 3310 views | 5 replies |
KiddaMan
Design Center Error
Hello Team,
I was trying to modify my page fomats using the Design Center....and now I get this error when I try to edit:
Warning: fopen(../../themes/temp_editing/css/configurable.css) [function.fopen]: failed to open stream: No such file or directory in D:\Hosting\5972022\html\webassist\plugins\styler\styler.php on line 77
Warning: filesize() [function.filesize]: stat failed for ../../themes/temp_editing/css/configurable.css in D:\Hosting\5972022\html\webassist\plugins\styler\styler.php on line 78
Warning: fread(): supplied argument is not a valid stream resource in D:\Hosting\5972022\html\webassist\plugins\styler\styler.php on line 78
Warning: fclose(): supplied argument is not a valid stream resource in D:\Hosting\5972022\html\webassist\plugins\styler\styler.php on line 79
Warning: simplexml_load_file() [function.simplexml-load-file]: I/O warning : failed to load external entity "../../themes/temp_editing/theme_settings.xml" in D:\Hosting\5972022\html\webassist\plugins\styler\styler.php on line 82
Fatal error: Call to a member function asXML() on a non-object in D:\Hosting\5972022\html\webassist\plugins\styler\styler.php on line 95
What version of PowerStore 4? Is this site using PowerStore 4.5 or is it using a previous version of Power Store? If it is a version prior to 4.5, go to the power store download center page and look in the Known Issues section for a fix.
KiddaMan
I have updated all of the files per your instructions, but I still have the same issue.
Warning: fopen(../../themes/temp_editing/css/configurable.css) [function.fopen]: failed to open stream: No such file or directory in D:\Hosting\5972022\html\webassist\plugins\styler\styler.php on line 97
Warning: filesize() [function.filesize]: stat failed for ../../themes/temp_editing/css/configurable.css in D:\Hosting\5972022\html\webassist\plugins\styler\styler.php on line 98
Warning: fread(): supplied argument is not a valid stream resource in D:\Hosting\5972022\html\webassist\plugins\styler\styler.php on line 98
Warning: fclose(): supplied argument is not a valid stream resource in D:\Hosting\5972022\html\webassist\plugins\styler\styler.php on line 99
Warning: simplexml_load_file() [function.simplexml-load-file]: I/O warning : failed to load external entity "../../themes/temp_editing/theme_settings.xml" in D:\Hosting\5972022\html\webassist\plugins\styler\styler.php on line 102
Fatal error: Call to a member function asXML() on a non-object in D:\Hosting\5972022\html\webassist\plugins\styler\styler.php on line 115
KiddaMan
Thank You
Dani Chankhour
In order to fix the issue that you are having with IE9, i have attached a new mootools-core.js file that will need to replace your current file located under the js folder.
And to fix the issue with FF4, you will need to replace the slideshow.js file that is located under the galleries/slideshow_wide/js folder with the attached file.
let me know if you still have any questions.
