unable to generate the menu files
Thread begun 3/31/2011 7:33 am by JamieEff | Last modified 4/05/2011 7:15 am by Jason Byrnes | 3213 views | 5 replies |
JamieEff
Hi there
I am trying to get menuwriter to work.
basically, I can access and define the menu items and the theme etc, but when I come to create the files, the app just hangs and does nothing at all (see screenshot)
I have installed on 2 different machines and it happens on both
Am using Dreamweaver CS3, WIN7 Pro
Not sure what to do?
Please advise
Jamie
Delete the Dreamweaver Cache file from the users configuration folder:
what is the build number of your Dreamweaver installation?
Go to Hep -> About Dreamweaver. Click the about dialog box once to scroll to the end. post the buil number listed here back.
JamieEff
I will check out that PDF, thank you
In the meantime, the builkd is version 9.0 build 3453
(CSS Sculptor works fine albeit very very slowly when selecting items)
Jamie
build 3453 is a pre releae build of Dreamweaver CS3, which had a known issue with floated windows such as the menu floater in your issue.
the official release version of cs3 was build 3481. you can try installing the CS5 demo for testing, or contact Adobe to obtain a download for the CS3 build 3481 release.
JamieEff
Thanks for your response Jason and will check into that!
All the best
Jamie
you're welcome.
