Hide layer on page load
Thread begun 3/29/2011 7:36 am by Rune Brynestad | Last modified 3/30/2011 6:28 am by Jason Byrnes | 2719 views | 5 replies |
Rune Brynestad
I have a page that contains 4 file fields. I want to show only the first 2 on page load. To get this to work I have wrapped a div called "extra" around the last 2 file fields and applyed the show/hide layer behavior to the body tag as shown in the attached picture.
It's working, but there is a big space between the first 2 file fields and the submit button. Is it possible to avoid that?
You can see a live URL here: Test.php
I'm also attaching my working files.
Regards
Rune
Add the extra form elements to a Dreamweaver AP Layer
to add the AP layer, go to Insert -> Layout Objects -> AP Div. Once the AP Div is created move the elements you want to hide inside the AP Div.
Rune Brynestad
Yes this is much better.
When I click the "Yes" radio button I want to show the AP layer I hided on page load. I have applyed the show/hide layer behavior to the "Yes" radio button as shown in the attached picture.
When I click the "Yes" radio button, it don't look good.
I'm also attaching my new working files.
Regards
Rune
OK, change of tack.
Why not use a spry collapsible panel. the pry collapsible panel is made to expand and contract the way you are looking for.
and the settings can be easily set for the default state to be closed.
Rune Brynestad
Yes, a spry collapsible panel is a better choice. It works perfect for this case.
Thanks again for helping me.
Regards
Rune
you're welcome.
