DFP and Data Assist
Thread begun 6/29/2009 9:14 am by Steve | Last modified 6/30/2009 10:11 am by Steve | 3802 views | 5 replies |
Steve
DFP and Data Assist
Hello,
A couple problems I have ran into with this combination (most recent versions) are as follows:
1 ) The recordset can not be generated if you specify localhost with a port designation. For instance localhost:3307
To get around this you have to use a named server or the IP address then the : port #... DW can handle localhost:port number without error though...
2 ) Saving and updating an uploaded file.
Without using the wizard set of insert, update DA and DFP work nice together allowing you to create your own pages then add the update and insert functionality. But the options for saving the file name seems to lack the ability of the full file name. This leaves us inserting the [name] but not the [type] (gif , jpeg, pdf, etc). It would be nice if DFP had an option to allow you to have the name and type (extension) concatenated so uploading gifs and jpgs could be used interchangeably in other dynamic pages.
3) Updating a record that already has an image uploaded. I'm not sure how the extension expects to handle the case when you have a record you are updating but do not want to upload a new image. Seems some logic like if imageName isset or !empty do not pass the values for the file field. But it you did chose a new image, then use the file fields [name].[type] as the text to insert in the record.
It was easy enough to create a linked page that passes the recordID and allows a new image upload and remove the file field from the update page, but this is not the most efficient method and in the Adobe Developer Toolkit there seems to be this logic so one page could efficiently handle a new image update or leave the prior undisturbed if not needed to be changed.
Maybe being able to use localhost : port # , actual filename (based on concatenated array values of [name].[type] , and an aware update behavior that allows prior unchanged file field values or new uploads to all work well together would be a consideration in some update version...?
1) What recordset? Where do you get this error. I'm not exactly sure of the problem so I'd like to reproduce it.
2) The full server file name should be available through bindings as well as the file name and extension individually.
3) This is correct it doesn't have the option to ignore or cancel the upload if the file exists, only to overwrite or rename.
Steve
1) Create a DB connection and use the logic I noted. Then try to find any table when you first open the Update Record Wizard. You'll be able to selection your connection file but no tables will be offered. It may be that no DBs are offered but since I've moved on from that roadblock I am not sure.
2) I don't see it. Screen shot attached
3) Please consider passing this to the powers that be as a viable update/enhancement. An update page should be able to actually update without requiring every value to be changed. Having to bounce to a second page to change out an image is not as efficient as it could be. Check out your copy of ADDT (if you have one) as i've done this on a number of prior occasions. But since Adobe is planning to shelve that product, it's forcing some of us to buy WA extensions (or properly learn PHP and save our snippets as we should) as a replacement. So if you have this, we will not need to learn the means to accomplish this on our own (counter productive to your Marketing teams goals).
1) Thanks I will try to reproduce it
2) It is in the file upload bindings above, not in the form field bindings.
3) Thank you for the suggestions
digitaldesign
1) I've had this happen sometimes when the testing server URL was incorrect
Steve
Originally Said By: digitaldesign
Not relative to this thread as there is not a problem creating a DB connection script in DW to use localhost and a specific port number.
In some cases we need to have specific ports rather than the default 3306. In this case I have some old clients that are not willing to update their old sites and their DB is in an earlier version than MySQL 5. So we run two instances of MySQL, one old version and one new version...using a different port for each of the two MySQL servers.
