URGENT: DB Issue with host (PS4.5)
Thread begun 3/22/2011 1:39 pm by robert329616 | Last modified 3/23/2011 11:28 am by Jason Byrnes | 3205 views | 5 replies |
robert329616
I just received an email from my host GoDaddy informing me that they have disabled my database is being over utilized. Here is part of the email that they have sent to me:
We have disabled your database to return the server to normal usage. To re-enable your database, you will need to correct the following query:
Problematic query:
SELECT *, coalesce((select ps4_productoptions.GroupingID from ps4_productoptions WHERE ps4_productoptions.ProductID = ps4_products.ProductID limit 1),ps4_products.ProductID) AS GroupingID FROM ps4_products WHERE ProductLive = 1 AND (ProductStartDate IS NULL OR ProductStartDate <= CURDATE()) AND (ProductEndDate IS NULL OR ProductEndDate >= CURDATE()) AND ProductID IN (SELECT ProductID FROM ps4_productcategories WHERE (CategoryID = 4)) GROUP BY GroupingID ORDER BY ProductName
EXPLAIN:
id select_type table type possible_keys key key_len ref rows Extra
1 PRIMARY ps4_products ALL 1013 Using where; Using temporary; Using filesort
3 DEPENDENT SUBQUERY ps4_productcategories ALL 844 Using where
2 DEPENDENT SUBQUERY ps4_productoptions ALL 6070 Using where
This query examines 5189680040 rows, which is unacceptable in shared hosting. Access will reinstated upon request.
Any help would be greatly appreciated as the site is completely down and I am losing customers.
Thanks.
Regards,
Robert
how many products do you have set up and how many options for each?
judging by the number of records being searched, it sounds like you have a lot of advanced options set up. you should evaluate whether some of them can be simple options instead of advanced options.
robert329616
Jason,
In my product area I have 2 Items with multiple options:
4 types of shafts; each has 7 thread sizes and 2 tip options
Anvil JB Cue - 3 types; each has 7 weights 7 colors and 2 tip options
Another JB cue just has 7 weights as options. The rest are really simple.
Does that seem like a lot of options that could be causing the issue?
The site is babysproshop.com. Should I be using simple options for these?
Rob
That does not sound like a lot of options that should cause this problem.
It could be that there are orphaned Options in the options table, or orphaned products in the products table.
How many records are there in each of those tables?
Your product results page only shows 17 products.
each advanced option you create will effectively add another product record. that's about 60 more records for the product combination's you describe which is nowhere near the 5189680040 that go daddy is claiming.
Simple options should be used for any options that do not need to have a unique description, SKU or price.
robert329616
I have 159 records in Options
1,013 records in Products
6,070 records in product options
How would I determine what an orphan is and what would be the best way to get rid of it?
Also, do these numbers sound like it would cause the issue?
