insert select list value from css form builder to db
Thread begun 3/22/2011 11:40 am by contact318852 | Last modified 3/22/2011 3:22 pm by Jason Byrnes | 3274 views | 5 replies |
contact318852
I created a form with css form builder 2 in dreamweaver cs3 and the email functions of the form are working as expected. One of the form elements is a select list.
I then created a dataassist insert record behavior to have the form fields entered into a database.
All of the fields populate the database except the select list data.
when I click on the field and choose the dynamic data this is what I get:
<?php ((isset($_POST["career_position[]"]))?$_POST["career_position[]"]:"") ?>
and in the insert record server behaviour I have this:
<?php echo ((isset($_POST["career_position[]"]))?$_POST["career_position[]"]:""); ?>
Does this look correct?
I cant understand why the email is able to select the dynamic/list menu value but the insert record behaviour can not.
this code:
should be changed to:
<?php echo ((isset($_POST["career_position"]))?implodes(", ",$_POST["career_position"]):""); ?>
contact318852
Thanks,
That returns an error
Fatal Error Call to undefined function implodes() in /home ....
I just changed the code in the insert record behaviour do I need to change it elsewhere as well?
I'm sorry, the s in implodes is a syntax error, it should be:
<?php echo ((isset($_POST["career_position"]))?implode(", ",$_POST["career_position"]):""); ?>
contact318852
Thank you, Its all fun and games until someone misplaces an s ;)
that works
glad to hear it is working.
