Error when submitting a page
Thread begun 3/21/2011 12:33 am by Daryl | Last modified 6/18/2011 7:34 pm by neo314 | 7874 views | 9 replies |
DarylBeta Tester
I have a DA page that contains UE
When the forum is submitted a record is updated and an email sent however I get the folloewing error page in google chrome...
The website encountered an error while retrieving water_companies2_checked.php. It may be down for maintenance or configured incorrectly.
The page mentioned in the error is the same page that the form is on that was just submitted
The page should get redirected to submitted.php
So I guess there is an error when the page is submitted.
we would need to know the PHP error to be able to troubleshoot.
try adding this code at line 1:
error_reporting
(E_ALL);
if this does not show the actual error on the page, you will need to look into the servers error logs to find the error. Once we know the PHP error, we can troubleshoot it.
DarylBeta Tester
This is the error that I get
  Fatal error: Cannot redeclare wa_ab_getloopedfieldname() (previously declared in /home/sites/domain.co.uk/public_html/WA_DataAssist/WA_AppBuilder_PHP.php:11) in /home/sites/domain.co.uk/public_html/webassist/database_management/wa_appbuilder_php.php on line 19
in the webassist/mail/mailformatting_php.php file, comment the following line:
require_once("../database_management/wa_appbuilder_php.php");
DarylBeta Tester
That got rid of the error and the redirect worked...
...just need to get the client to test it.
glad to hear it is working.
neo314
I just ran into this problem. I suggest that changing the line to:
if (!function_exists("WA_AB_getLoopedFieldName")) { require_once("../database_management/wa_appbuilder_php.php"); }
might be better.
This occurred because require_once prevented the same file from being included twice, but because of the change to move all WA includes into a single directory (a great move) two different files contained the same function.
This code tests whether or not the old file [location] has already been included and, if not, includes the new file.
Otherwise, I believe if you add an email with dynamic elements to another page which does not already include either version of wa_appbuilder_php.php, the second email procedure will fail. Am I right on this Jason?
It would be nice, due to this transition to moving all the include files into the "webassist" directory, if the new files checked for preexisting includes in the old directory structure (by function test I suppose) to prevent this kind of conflict from occurring.
P.S. While I cannot be responsible for any harm that might come from this fix, I placed the code I recommended into the file located in C:\Users\[USER_NAME]\AppData\Roaming\Adobe\Dreamweaver 9\Configuration\Shared\WebAssist\UniversalEmail\MailFormatting\MailFormattingPHP.php on my Windows 7 machine and now the file recreates with this code in it. Problem solved unless Jason points out a flaw in my reasoning.
Thanks for posting this, that is how it will be fixed in a future update.
Jenny I
Same problem
I am encountering the same problem. However when I appiled your fix I am now getting this error
Fatal error: Cannot redeclare wa_ab_getloopedfieldname() (previously declared in /home/theacts1/public_html/WA_DataAssist/WA_AppBuilder_PHP.php:11) in /home/theacts1/public_html/webassist/database_management/wa_appbuilder_php.php on line 19
neo314
That is strange because the function is called WA_AB_getLoopedFieldName() and I think, even on a windows case-insensitive machine the error message should present the correct case, plus case-insensitivity should not apply to functions.
Did you look at the file to see if the name of the function is wa_ab_getloopedfieldname() or WA_AB_getLoopedFieldName() ?
