htaccess
Thread begun 3/17/2011 1:10 pm by mick106153 | Last modified 3/18/2011 10:38 am by Jason Byrnes | 5590 views | 11 replies |
mick106153
htaccess
I tried Erics suggestion
<?php if((!(isset($_SERVER['HTTPS']))) || ($_SERVER['HTTPS'] == "") || ($_SERVER['HTTPS'] == "off"))header("Location: https://" . $_SERVER['HTTP_HOST'] . $_SERVER['PHP_SELF']); ?>
found in this post
showthread.php?t=13376&highlight=secure+site
and I get a too many redirects failure.
Suggestions?
Mick
use an htaccess rule instead of adding php code to the page:
force-ssl-htaccess.html
mick106153
I did that first and it failed too.
I created an .htaccess file in the root of my site to throw everything into https and
with www.battleoflakeerie-bicentennial.com
I get a "too many redirects"
with battleoflakeerie-bicentennial.com
I get a mismatch
Mick
you should work with your host on this then, since this falls under the category of server configuration.
mick106153
Well no wonder!
Now they tell me it won't work with php or htaccess.
I need a javascript file which they will kindly make me for $59.95.
Any idea how to do this with javascript or where to look?
Mick
mick106153
OK
I have a javascript that works.
I'm using it as an include in the site proper.
How would it be best to include it in the store as a whole?
Mick
I'm not familiar with using javascript to force access to the site using HTPPS, but it would integrate with power store the same way it integrates into your regular site.
This does not seam to be a good way to do this to me though since javascript can be disabled in the clients browser.
to be honest, i have never dealt with a host that did not support forcing https using PHP or htaccess, I would be a little weary of this host.
mick106153
Well you certainly know more about these things than I do.
And I found it strange as well.
Network Solutions is the host and I'm on a unix server. The tech there, also knowing way more about these things than I do, gave a convincing argument as to why though I can't quote his reasons.
I've been with them for a long time and am reluctant to move but will if you think it's the best thing to do.
FYI this is the script…
<script language="javascript">
if (document.location.protocol != "https:")
document.location.href = "https://www.battleoflakeerie-bicentennial.com" + document.location.pathname;
</script>
I dont really know what convincing argument there could be for having the client computer determine whether the page is accessed using SSL.
The issue i see is this:
You as the site developer want to force the clients experience when browsing your site to use a secure HTTPS connection.
By using javascript, the choice is no longer yours really, it is up to the client browser.
If the client browser has disabled javascript, the site visitor will not be sent to the secure HTTPS address, they will remain on the HTTP address.
To use that javascript, you would add it to the html code of the power store pagess.
mick106153
When I say convincing, I mean in the sense that it was convincing to me because I know nothing and he spoke with apparent authority.
Now that I've read what you have to say it makes complete sense.
I've also discovered that the code he provided throws an error on every page visible if viewed in FireFox with FireBug.
I will attempt to convince them of their error.
Can you suggest a host with 24x7 live tech?
As always
Your obedient servent
Mick
