Multiple folders using multipe extensions
Thread begun 3/04/2011 8:27 am by michael419508 | Last modified 3/04/2011 9:45 am by Jason Byrnes | 2032 views | 1 replies |
michael419508
Probably answered somewhere just can’t find it.
I just want to make sure I understand this going forward.
I hope to create several site definitions in Dreamweaver. Each one will host different forms. Which may include dataassist, security assist, webassist etc.
Then when things are working I want to upload each site folder to one live site. In other words one root folder containing multiple site folders as described above and below.
Example below
public_html/formfolder1/Connections
public_html/formfolder1/webassist
public_html/formfolder1/WA_SecurityAssist
public_html/formfolder1/WA_DataAssist
public_html/formfolder1/ index.php
public_html/formfolder1/ contactform.php
And so on
public_html/formfolder2/Connections
public_html/formfolder2/webassist
public_html/formfolder2/WA_SecurityAssist
public_html/formfolder2/WA_DataAssist
public_html/formfolder2/ index.php
public_html/formfolder2/ contactform.php
public_html/formfolder3/Connections
public_html/formfolder3/webassist
public_html/formfolder3/WA_SecurityAssist
public_html/formfolder3/WA_DataAssist
public_html/formfolder3/ index.php
public_html/formfolder3/ contactform.php
Does seem to work, however does create multiple copies of folders for webassist etc.
The advantage I see is I can port to any server or subfolder and they work.
Is this the way I should continue or am I out to lunch here? I have read in different places that dataassist is suppose to be in the root of the site....but I assume this means not buried in the subfolder such as this example:
public_html/formfolder1/Subfolder/WA_DataAssist
Using Dreamweaver CS5 and Super Suite latest version. Win7 64bit
Thanks Kindly
Michael
yes, that is the way you should continue.
each site should have a unique folder under the public_html folder.
this is in relation to the Dreamweaver site definition, not the actula site files on your server.
