Update not working
Thread begun 2/28/2011 1:14 pm by paul307749 | Last modified 3/28/2011 2:28 pm by Jason Byrnes | 6094 views | 11 replies |
paul307749
Update not working
I'm trying to get the Update record behaviour to update records in the database, and so far it won't make any changes at all.
I've tested the same techniques using the standard DW server behaviour, and this works perfectly.
I'm using the latest version of DataAssist in conjunction with the latest version of Framework Builder and while everything works as expected, the update makes no change to the database at all.
Has anyone else come across this issue or anyone got any idea as to why the update would fail?
I've rebuilt the page on several occasions to check everything is as it should be, and as far as I can see there are no configuration issues to cause this problem.
Help, I'm getting to the point of deleting DA and going back the ADDT!!
Paul C
please send a copy of the update page.
paul307749
Hi Jason,
Could you let me have the preferred email address so I can send you the file please?
Regards
Paul
compress the page to a zip archive and you can attach it directly to this forum.
paul307749
Hi Jason,
This should be the latest version of the file.
Regards
Paul
in he update record server behavior, you have bound all of the Table columns to the record set values.
you need to bind the table column in the update record server behavior to the corresponding form elements instead.
for each table column, click the lightning bolt. On the bindings panel, expand the form collection and select the corresponding form element.
paul307749
Hi Jason,
Sorry, I must have uploaded an old version where I was trying to get things working.
I've attached the correct file and checked that it using the relevant form elements as outlined in your previous post.
I've tested with the attached file and the update still isn't being carried out.
Any help would be appreciated.
Paul C
in the column bindings, you have set the cat ID value to update using the value from the form, you should not bind the catID primary key column to anything, the database will not allow the primary column value to be changed.
if it is still not working, clear the redirect value in the update record behavior, then add the following code just after the ,body> tag:
SQL: <php echo($WA_Sql); ?><br />
this will write the update SQL Statement to the page for troubleshooting.
paul307749
Hi Jason,
I've tried what you suggested and I'm still not getting any success.
The SQL statement returns nothing, just blank even when I get the update to work outside the Framework.
If I don't use the Framework I can get the update to actually work, but once I put it back inside the framework it stops updating the database.
What exactly is intended to be put into the form action to work with the Framework? Should it now be the actual URL plus framework mod (i.e page=list-category) or should it be something different.
Do I need to fill anything in the 'After Update go to' section of the SB?
This is all straightforward when it's used on it's own, but add the Framework in and it's become an absolute nightmare. Surely getting 2 of your products to work as intended shouldn't be this difficult!
My apologies if I'm sounding annoyed, but this issue is seriously slowing down 2 important projects I'm working on.
Regards
Paul
the forms action should be set the url used to load the update page.
so if the update page is access as:
index.php?page=list-category
then the forms action should be set to:
action="index.php?page=list-category"
the redirect can be left blank, or it can be set to load another page, that is up to you.
