Sub Menu not showing
Thread begun 2/19/2011 5:37 am by les179372 | Last modified 3/07/2011 6:40 pm by neilo | 3503 views | 7 replies |
les179372
Can anyone help with this?
I am struggling with Z index to show sub menu on the following draft page: StarWars.php#
Can anyone help?
neilo
Hi Les,
Try changing overflow:hidden to overflow:visible in your includes/CSSLayouts/CSSLayouts.css stylesheet (line 24)
.cssLO > .cssLI:first-child {
overflow: visible;
les179372
Originally Said By: neilo
  Hi Les,
overflow: visible;
Thanks Neilo,
Worked fine. Just a bit of tweaking to to complete with sizes etc.
neilo
Cheers Les,
You may also want to play with the width of the Level-1 menu, and add a 'white-space:normal;' property to the rule in CSSMenuWriter/cssmw/menu.css (line 105) in order to fit the longer text links. The 'white-space:normal' property will allow the text to wrap:
ul#cssmw ul.level-1 > li > a, ul#cssmw ul.level-1 > li > a:link {
background-color: #FFFF00;
background-image: none;
border-bottom: 1px solid #FFFFFF;
border-right: 1px solid #FFFFFF;
color: #173232;
display: block;
font-family: "Trebuchet MS",Helvetica,sans-serif;
font-size: 10px;
font-style: normal;
font-weight: bold;
margin: 0;
outline-style: none;
padding: 5px;
text-decoration: none;
text-transform: uppercase;
white-space: normal;
width: 120px;
Looking good.
les179372
Cheers Neilo,
Great tip.
Navigation now starting to take shape.
malcolm230194
CSSMenuWriter in particular but WebAssist in general
This software seems to generate more corruptions than valid code. I spend more time debugging the shaky generated code than getting any work done. Maybe that's why this forum seems to be busy?
I have the same problem with identical code on two different sites. Works on one, not the other. I've got up to z-index 5000 but it won't play.
In the long run it will be easier to go back to the old way of writing my own menus.
This software is counter intuitive and unstable. I for one give up.
If you post the url to the page where you are having trouble someone would probably be able to help. Often times it just takes a small tweak in the css.
neilo
This could easily indicate a conflict in (the order of) the CSS that governs the way the menu presents. The style rules 'Cascade' (Cascading Style Sheets!) so a rule in another stylesheet may be superceding the correct rule for your menu's proper functioning/appearance.
As Ray says, link to the page(s) and we should spot the problem.
