page protection error
Thread begun 2/10/2011 2:29 pm by Paul | Last modified 2/15/2011 2:57 pm by Paul | 2514 views | 4 replies |
PaulBeta Tester
I've used DA wizard to create a set of pages accessed by logged in users
I then used SA Page Access to protect these pages.
The following code snip is present at the top of each page i wish to protect
if (!isset($_SESSION)) {
session_start();
<?php require_once('../******/********.php'); ?>
<?php virtual( "/WA_SecurityAssist/Helper_PHP.php" ); ?>
if (!WA_Auth_RulePasses("Logged in to **_****")){
WA_Auth_RestrictAccess("/members/login.php");
If after i login and attempt to access any of these pages, a "HTTP Error 500 (Internal Server Error)" page loads.
DW CS5 does not report any code errors.
Any ideas on where i could be going wrong?
500 server errors are very generic. they only mean that "an error has occurred" they are generally used to hide the actual error from the user, but are of no help when developing.
Is this on a local or remote testing server?
try adding the following code at line 1, this may show the actual error so we can get an idea of the problem:
error_reporting
(E_ALL);
PaulBeta Tester
Thanks Jason.
This is the output after including code as instructed;
Warning: require_once(/WA_SecurityAssist/Helper_PHP.php) [function.require-once]: failed to open stream: No such file or directory in /home/www/peedoff.net/members/profile.php on line 11
Fatal error: require_once() [function.require]: Failed opening required '/WA_SecurityAssist/Helper_PHP.php' (include_path='.:/usr/local/php5/lib/php') in /home/www/peedoff.net/members/profile.php on line 11
..and this is line 11;
<?php require_once( "/WA_SecurityAssist/Helper_PHP.php" ); ?>
Paul.
try changing:
to either:
<?php require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>
or:
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
PaulBeta Tester
Resolved, Thanks J.
