Problems editing design in PowerStore 4.0.1
Thread begun 2/08/2011 5:29 pm by lmound389223 | Last modified 3/29/2011 1:20 pm by Jason Byrnes | 5874 views | 6 replies |
lmound389223
Installed PowerStore 4 and it was successful. went into admin to edit design. after a few edits the system locked. logged out, logged back in and now the design mode will not work. I get the this trying to edit any theme: Need help.
Warning: fopen(../../themes/temp_editing/css/configurable.css) [function.fopen]: failed to open stream: No such file or directory in /data/22/2/12/92/2012092/user/2201584/htdocs/pureyestore/webassist/plugins/styler/styler.php on line 77
Warning: filesize() [function.filesize]: stat failed for ../../themes/temp_editing/css/configurable.css in /data/22/2/12/92/2012092/user/2201584/htdocs/pureyestore/webassist/plugins/styler/styler.php on line 78
Warning: fread(): supplied argument is not a valid stream resource in /data/22/2/12/92/2012092/user/2201584/htdocs/pureyestore/webassist/plugins/styler/styler.php on line 78
Warning: fclose(): supplied argument is not a valid stream resource in /data/22/2/12/92/2012092/user/2201584/htdocs/pureyestore/webassist/plugins/styler/styler.php on line 79
Warning: simplexml_load_file() [function.simplexml-load-file]: I/O warning : failed to load external entity "../../themes/temp_editing/theme_settings.xml" in /data/22/2/12/92/2012092/user/2201584/htdocs/pureyestore/webassist/plugins/styler/styler.php on line 82
Fatal error: Call to a member function asXML() on a non-object in /data/22/2/12/92/2012092/user/2201584/htdocs/pureyestore/webassist/plugins/styler/styler.php on line 95
Could be a permissions problem. double check that the webassist/themes directory, and all child directories, has 777 permissions granted.
It could also be that the temp_editing/css/configurable.css has become corrupted.
You could try deleting the webassist/themes/temp_editing/ directory from the server, it will be recreated the next time you attempt to edit the theme.
lmound389223
PowerStore not functioning
I totally reinstalled the store 3 times and every time it installs successfully. and I can proceed to admin. As soon as I start to add content or edit the theme design it goes nuts. The css seems to go whacky even for the structure of the store itself, and the format falls apart. while trying to save changes it locks up and then I cannot get back into the admin.
This purchase has been extremely disappointing. I need to get this store up and running and I can't even add content
lmound389223
additional issue
Also if I try to save the changes as a new theme after the first attempt it locks up and gets stuck. The permissions are all on 7 with the exception of "write everyone" the server will not allow me to insert a seven for the check box. it automatically clears that out . Our host is is Network Solutions.com Are there compatibility issues with this host provider? Help!!
david49463
Same problem here
I have the same problem with a new installation of 4.5, all file permissions on 777 and with the temp directory deleted, tried with 2 browsers (IE and Safari). Still get the same error message and a crash:
Warning: simplexml_load_file() [function.simplexml-load-file]: ../../themes/temp_editing/theme_settings.xml:1: parser error : Unsupported encoding windows-1256 in /mnt/web5/43/92/5107192/htdocs/mcnaughtan_de/webassist/plugins/styler/styler.php on line 104
Warning: simplexml_load_file() [function.simplexml-load-file]: <?xml version="1.0" encoding="windows-1256"?> in /mnt/web5/43/92/5107192/htdocs/mcnaughtan_de/webassist/plugins/styler/styler.php on line 104
Warning: simplexml_load_file() [function.simplexml-load-file]: ^ in /mnt/web5/43/92/5107192/htdocs/mcnaughtan_de/webassist/plugins/styler/styler.php on line 104
Fatal error: Call to a member function asXML() on a non-object in /mnt/web5/43/92/5107192/htdocs/mcnaughtan_de/webassist/plugins/styler/styler.php on line 117
So what now?
Further detail: I am now unable to change theme
