Different amount of options
Thread begun 1/26/2011 3:59 am by moz1104419172 | Last modified 2/15/2011 8:11 am by Jason Byrnes | 2339 views | 3 replies |
moz1104419172
Im looking to build a site to sell varying products, mainly things such as shirts and tops.
My issue is some of my products will have 2 options (size/colour) and some might have more or less. is there a way to make the dynamic product page show product options depending on how many different options they have?
On the eCart support page, there is a tutorial for using product options, this uses a recordset to populate the options list.
you could select the option list, then add a show if region. go to the Insert Panel, click the plus button and select Show If, for the trigger select Recordset 'option recordset' not empty, where option recordset is name of the recordset used to populate the list.
moz1104419172
Apologies for the delay between messages
Im having trouble following your suggestion, im not sure where or how to use the tshow property
The Show If option is a behavior on the Server behaivors panel
In design view, select the your option select list.
Go to Window -> Server Behaviors
In the server behaviors window click the plus button and select Show If.
Select Recordset <Option recordset> Not Empty
Where <Option recordset> is the recordset that is used to populate the option list.
